Fast Unlocker | 08-02-2018 08:35 | have tried to write boot 1 and boot 2 and even EXT from support and here is log Code:
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : K430DS
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_K430DS_EMMC.srf
Voltage : 3.3V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC QE13MB
Page size : 512 B
Block size : 512 B
Block count : 30535680
Size : 14.56 GB (14910.00 MB)
CID Info
CID : 150100514531334D420D9E09D3EB54A3
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : QE13MB
Product revision : 0.13
Product serial number : (hex) 9E09D3EB
Manufacturing date : 05/2017
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x40) 01000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7626752 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_01_08_2018_17_16_56.bin.
Connect successful.
SW: 1.6.4; FW: 1.24.
P00: FSBL (00000001, 00000028) 20 KB
P01: QCSBL (00000029, 00000800) 1024 KB
P02: OSBL (00000829, 00002000) 4 MB
P03: APPSBL (00020000, 00002000) 4 MB
P04: PART_2C (00022000, 00002000) 4 MB
P05: PART_58 (00024000, 00002000) 4 MB
P06: PART_77 (00026000, 0000C000) 24 MB
P07: BOOT (00032000, 00006000) 12 MB
P08: MODEM_ST1 (00038000, 00002000) 4 MB
P09: MODEM_ST2 (0003A000, 00002000) 4 MB
P10: AMSS (0003C000, 0000E000) 28 MB
P11: PART_6C (0004A000, 0000E000) 28 MB
P12: EXT2FS (00058000, 001D0000) 928 MB
P13: EXT2FS (00228000, 00006000) 12 MB
P14: EXT2FS (0022E000, 00140000) 640 MB
P15: PART_60 (0036E000, 00006000) 12 MB
P16: EXT2FS (00374000, 00004000) 8 MB
P17: PART_6B (00378000, 00006000) 12 MB
P18: EXT2FS (0037E000, 0038C000) 1816 MB
P19: PART_FF (0070A000, 00002000) 4 MB
P20: PART_FF (0070C000, 00002000) 4 MB
P21: EXT2FS (0070E000, 00008000) 16 MB
P22: PART_FF (00716000, 00002000) 4 MB
P23: EXT2FS (00718000, 00010000) 32 MB
P24: PART_FF (00728000, 00002000) 4 MB
Switched to boot area partition 1.
Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(BOOT1 LG K430DS) SAMSUNG EMMC Q316AB.BIN file...
Write data verification is enabled.
Writing. Please wait... Done.
Switched to boot area partition 2.
Opening C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(BOOT2 LG K430DS) SAMSUNG EMMC Q316AB.BIN file...
Writing EXT_CSD succesfully complete!
Disconnected. phone still dead if there is a way to upload dump to revive this phone this will help so much .
thanks |
