Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 07-07-2020, 11:20   #1 (permalink)
Member: 2749393
Thanks Meter: 39
LG vs450pp jtag problem [Answered]
Hello,
I can't repair lg vs450pp,
Welcome to Medusa Pro Software version 2.1.1.
Started.
Reader #0: Broadcom Corp Contacted SmartCard 0
Reader #1: Generic EMV Smartcard Reader 0
Reader #2: Generic EMV Smartcard Reader 1
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : D320n
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_D320N_EMMC.SRF
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC H4G1d
Page size : 512 B
Block size : 512 B
Block count : 2097152
CID Info
CID : 90014A4834473164040504A140558143
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H4G1d
Product revision : 0.5
Product serial number : (hex) 4A14055
Manufacturing date : 08/1998
CSD Info
CSD : D02701320F5903FFFFFFFFEF8A4040D3
CSD structure : CSD version No. 1.0
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.0 (for MMC v4.0)
Erase block size : 65536 Kbytes
Boot1 size : 384 Kbytes
Boot2 size : 384 Kbytes
RPMB size : 0 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Max enhanced data size: 0 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G1d_07_07_2020_13_16_09.bin.
Connect successful.
SW: 2.1.1; FW: 1.24.
---------------------------------------------------------------Searching Android build info...
Not found
---------------------------------------------------------------Remove write protect error.
Disconnected.
Model Settings:
Interface : eMMC
Brand : LG
Model : D320n
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
Block count : 7634944
CID Info
Manufacturing date : 08/2014
CSD Info
CSD structure : CSD version No. 1.2
TRAN speed : 26 MHz
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
(Bus width = 1Bit)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 1908736 Kbytes
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G1d_07_07_2020_13_16_34.bin.
Connect successful.
Not found
---------------------------------------------------------------Opening D:/Lg VS450PP/VS450PP1_04.kdz file...
Write data verification is enabled.
Writing. Please wait...
Writing partition PrimaryGPT...
Read/write verification error. Possible reasons: damaged or write protected eMMC.
Disconnected.
Please help
Old 07-07-2020, 12:17   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
Please, make sure that You've solder everything correctly, try to add resistors (150Ohm-390Ohm) to D0 --> 1V8" or "CMD --> 1V8" also try to set lover Speed
Old 07-07-2020, 16:33   #3 (permalink)
Member: 2749393
Thanks Meter: 39
Originally Posted by Octopus box View Post
Hello.
I tried with 10 MHz but still problem.
Started.
Model Settings:
Interface : eMMC
Brand : LG
Model : D320n
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : 10 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G1d_07_07_2020_18_20_28.bin.
Connect successful.
Not found
---------------------------------------------------------------Disconnected.
Model Settings:
Interface : eMMC
Brand : LG
Model : D320n
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : 10 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H4G1d_07_07_2020_18_20_31.bin.
Connect successful.
P00: GPT (00000000, 00002000) 4 MB
P01: modem (00002000, 00020000) 64 MB
P02: sbl1 (00022000, 00000800) 1024 KB
P03: rpm (00022800, 00000400) 512 KB
P04: tz (00022C00, 00000400) 512 KB
P05: sdi (00023000, 00000400) 512 KB
P06: aboot (00023400, 00001000) 2048 KB
P07: rpmb (00024400, 00000400) 512 KB
P08: tzb (00024800, 00000400) 512 KB
P09: abootb (00024C00, 00001000) 2048 KB
P10: pad (00025C00, 00001000) 2048 KB
P11: modemst1 (00026C00, 00001800) 3072 KB
P12: modemst2 (00028400, 00001800) 3072 KB
P13: misc (00029C00, 00008000) 16 MB
P14: persist (00032000, 00010000) 32 MB
P15: laf (00042000, 0000B000) 22 MB
P16: boot (0004E000, 0000B000) 22 MB
P17: recovery (00059000, 0000B000) 22 MB
P18: fsg (00064000, 00001800) 3072 KB
P19: fsc (00066000, 00000400) 512 KB
P20: ssd (00066400, 00000400) 512 KB
P21: DDR (00068000, 00000400) 512 KB
P22: encrypt (0006A000, 00000400) 512 KB
P23: rct (0006A400, 00000400) 512 KB
P24: drm (0006C000, 00004000) 8 MB
P25: sns (00070000, 00004000) 8 MB
P26: factory (00074000, 0000A000) 20 MB
P27: fota (0007E000, 00010000) 32 MB
P28: sbl1b (0008E000, 00000800) 1024 KB
P29: eri (0008E800, 00004000) 8 MB
P30: eksst (00092800, 00000400) 512 KB
P31: system (00094000, 0028A000) 1300 MB
P32: cache (0031E000, 0004B000) 150 MB
P33: userdata (00369000, 003D4400) 1960 MB
P34: grow (0073E000, 00009FDF) 19.98 MB
Backuping modemst1 partition...
Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/H4G1d_modemst1_0x26c00_0x1800_07_07_2020_18_20_31. bin file...
Reading. Please wait...
ERROR[011]: Read error.
Attempting to read...
Done.
Elapsed time 00:00:03
Backuping modemst2 partition...
Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/H4G1d_modemst2_0x28400_0x1800_07_07_2020_18_20_31. bin file...
Reading. Please wait... Done.
Elapsed time 00:00:02
Backuping fsg partition...
Opening C:/Program Files (x86)/Octoplus Pro JTAG Software/Backups/H4G1d_fsg_0x64000_0x1800_07_07_2020_18_20_31.bin file...
Ok
Disk/Image size : e9000000 bytes
Device sector size : 512 bytes
Partition offset : 606208
Number of sectors : 2662400
Device Manufacturer : lge
Device Platform : msm8610
Build ID : KOT49I.VS450PP1
Display Build ID : KOT49I.VS450PP1
Release ID : 4.4.2
Device Model : LG-VS450PP
Device Name : w5c_vzw
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Build Description : w5c_vzw-user 4.4.2 KOT49I.VS450PP1 VS450PP1.1393919562 release-keys
Read verification error 1. Possible reasons: damaged or write protected eMMC.
Disconnected.
Page generated in 0.17987 seconds with 8 queries
