Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 05-27-2017, 19:43   #1 (permalink)
Member: 1703595
Thanks Meter: 62
why xml write for qualcomm option is disabled
Hi octoplus supporter
why the option "Repair devices based on Qualcomm CPU's using XML files"
is desabled and when the option enabled
Old 05-29-2017, 07:14   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hi.
What type of connection do You use? Note, this option will be available, only when You connect the device via USB using general Qualcomm loaders ("QLoader") in Software. This option will be disabled, if You connect the device via eMMC. Please look here: http://forum.gsmhosting.com/vbb/f664...l#post12247316:
- Released writing factory firmware via USB for devices, based on Qualcomm CPUs.
Old 05-29-2017, 09:03   #3 (permalink)
Member: 1703595
Thanks Meter: 62
Originally Posted by Medusa Box View Post
Hi.
may you enable this option in emmc connection mode for programming blank emmc using emate pro before soldering on board?
Old 05-29-2017, 09:20   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Currently this is not possible, writing of XML firmware via USB uses Qualcomm loaders CMDs and not supported via eMMC.
Page generated in 0.12501 seconds with 8 queries
