08-17-2017, 13:21 | #1 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1784601 Status: Offline Thanks Meter: 21 | Can't repair boot i9070 I'm trying to repair a dead samsung i9070. I have already solder the wire to the RJ50 cable and connect it to the octoplus. Then, I've pluged the USB cable into the PC. Windows recognize and install the phone like a u8500 Rom USB. After that, I will start the procedure for fix the phone, but systematically the phone goes in something like a bootloop (turning on and off). I can hear the sound of windows (plug in--->plug off). Welcome to Octoplus JTAG Box Software version 1.9.5.4 To make Repair Samsung GT-I9070 You need: 1. Connect it via Jtag cable to Box. 2. Connect to PC via USB cable (use both connection). 3. Install U8500 driver (if driver was not installed automatically) from folder "C:\Program Files\GSMServer\Medusa\Driver\U8500\" and try to connect the phone again. Note: This phone can connect more longer, so You need to wait 30-50 seconds. Selected device model: Samsung GT-I9070 Connecting. Please wait... Checking data... Resetting target. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... Resetting target. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 62286041, IR Length = 6. JTAG speed : 2400 KHz. VREF level : 1.75 V CPU : ST-Ericsson U8500 Core ID : 4BA00477 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Checking data... Resetting target. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 62286041, IR Length = 6. JTAG speed : 2400 KHz. VREF level : 1.76 V CPU : ST-Ericsson U8500 Core ID : 4BA00477 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Selected device model: Samsung GT-I9070 Connecting. Please wait... Checking data... Resetting target. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 62286041, IR Length = 6. JTAG speed : 1000 KHz. VREF level : 1.76 V CPU : ST-Ericsson U8500 Core ID : 4BA00477 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... Resetting target. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 62286041, IR Length = 6. JTAG speed : 1000 KHz. VREF level : 1.76 V CPU : ST-Ericsson U8500 Core ID : 4BA00477 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Checking data... Resetting target. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 62286041, IR Length = 6. JTAG speed : 1000 KHz. VREF level : 1.76 V CPU : ST-Ericsson U8500 Core ID : 4BA00477 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. I don't know what it's wrong. Thanks |
08-17-2017, 13:35 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please check soldering of all JTAG wires, make each of them as short as possible (max. 3-5 CM length) and try to connect again. To connect the device, perform the following steps: 1. Run Software. 2. Disconnect phone's battery. 3. Connect the phone to PC via USB cable directly to PC motherboard USB port, don't use USB hubs, this is important. 4. Insert the battery. 5. Install U8500 driver (if driver was not installed automatically) from folder "C:\Program Files\GSMServer\Medusa\Driver\U8500\" - as a result, "U8500 USB ROM" device should appear in PC Device Manager. 6. Disconnect phone's battery and USB cable. 7. Connect the device via JTAG cable to Box. 8. Connect to phone to PC via USB cable (use both connection). 9. Press "Connect" button in Software. 10. Connect phone's battery and wait 30-50 seconds till the device will be connected. Also, please look here: http://forum.gsmhosting.com/vbb/9423835-post1.html, http://forum.gsmhosting.com/vbb/f664...5/#post9592060, http://forum.gsmhosting.com/vbb/9504749-post564.html, http://forum.gsmhosting.com/vbb/f664...5/#post9585732, http://forum.gsmhosting.com/vbb/f664.../#post10277694, http://forum.gsmhosting.com/vbb/f664...4/#post9438787, http://forum.gsmhosting.com/vbb/9423877-post4.html. https://www.youtube.com/watch?v=nd1KQHI2tzw. |
