11-20-2017, 20:17 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1698387 Status: Offline Thanks Meter: 43 | Vodafone VF-1397 dead after remove FRP [Solved] Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Core : Qualcomm MSM8909 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_009600E1 Core : Qualcomm MSM8909 Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.1.0. P00: GPT (00000000, 00020000) P01: modem (00020000, 00020000) P02: tunning (00040000, 00000C00) P03: traceability (00040C00, 00000800) P04: fsc (00041400, 00000002) P05: ssd (00041402, 00000010) P06: sbl1 (00041412, 00000400) P07: sbl1bak (00041812, 00000400) P08: rpm (00041C12, 00000400) P09: rpmbak (00042012, 00000400) P10: tz (00042412, 00000400) P11: tzbak (00042812, 00000400) P12: pad (00042C12, 00000800) P13: hyp (00043412, 00000400) P14: hypbak (00043812, 00000400) P15: modemst1 (00043C12, 00000C00) P16: modemst2 (00044812, 00000C00) P17: simlock (00045412, 00000800) P18: efsdata (00045C12, 00000C00) P19: DDR (00060000, 00000040) P20: fsg (00060040, 00000C00) P21: sec (00060C40, 00000020) P22: aboot (00060C60, 00000800) P23: abootbak (00061460, 00000800) P24: boot (00061C60, 00010000) P25: recovery (00071C60, 00010000) P26: system (00081C60, 00400000) P27: persist (004A0000, 00010000) P28: reserved (004B0000, 0000A000) P29: splash (004BA000, 00004000) P30: tctpersist (004BE000, 0000A000) P31: hdcp (004C8000, 00005000) P32: fota (004CD000, 00000010) P33: cache (004CD010, 00080000) P34: misc (0054D010, 00000800) P35: persistent (0054D810, 00001000) P36: devinfo (00560000, 00000800) P37: keystore (00580000, 00000400) P38: config (00580400, 00000040) P39: oem (00580440, 00000080) P40: userdata (005804C0, 0179EB1F) Removing FRP. Please wait... Done. SW: 1.4.0; FW: 1.1.0. Disconnected. Last edited by Octopus box; 11-27-2017 at 06:05. |
11-21-2017, 06:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,438 | Hello. You should find and write original firmware for this device from "Qualcomm...9008" Mode. Connect the device in "Qualcomm...9008" Mode then go to "Factory Repair" tab of Software, select original firmware with "*.xml" and write it into your device. If You can't find proper firmware, You can read out full flash from the same working device model and write this full flash into your "dead" device. Also, please always use the latest Software version (https://octoplusbox.com/en/download/software/). |
