08-29-2019, 17:38 | #1 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 430749 Status: Offline Thanks Meter: 24 | I9195 EMMC repair? [Answered] Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9195 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9195_EMMC.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Sandisk eMMC SEM08G Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 45010053454D3038479001749AC531B7 Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SEM08G Product revision : 9.0 Product serial number : (hex) 1749AC5 Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFFF92404011 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 4096 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3768320 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/SEM08G_29_08_2019_13_28_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. smart repair fail: Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_GT-I9195_EMMC.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. remove write protect erro: SW: 1.7.7; FW: 1.24. Remove write protect error. Disconnected. |
08-30-2019, 06:48 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, check Software log: Write verification error 1. Possible reasons: damaged or write protected eMMC. Quote:
