starkrimes | 11-06-2019 09:56 | Oppo cph1803 pattern lock remove done without loosing data [IMG]****************************/convkey/8e12/om8kq3wzkjw64fszg.jpg?size_id=4[/IMG] MY 4TH HAND ON OPPO A3s CPH1803 PATTERN LOCK REMOVE DONE WITHOUT LOOSING DATA LOG INFO : Code:
Welcome to Octoplus Pro JTAG Software version 1.7.7. Started.
Reader #0: FT SCR2000 0
Reader #1: FT SCR2000 1
Reader #2: FT SCR2000 2
Reader #3: Generic Usb Smart Card Reader 0
Reader #4: Generic Usb Smart Card Reader 1
Reader #5: Generic Usb Smart Card Reader 2
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC QE63MB
Page size : 512 B
Block size : 512 B
Block count : 30535680
Size : 14.56 GB (14910.00 MB)
CID Info
CID : 150100514536334D42035E05CC4A45DD
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : QE63MB
Product revision : 0.3
Product serial number : (hex) 5E05CC4A
Manufacturing date : 04/2018
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x38) 00111000
Boot partition enable : User area
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7626752 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : a3e00000 bytes
Device sector size : 512 bytes
Partition offset : 2064384
Number of sectors : 7030784
Build ID :OPM1.171019.026
Release ID :8.1.0
Architecture ABI :arm64-v8a
Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi
Build Description :msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20180927.160930 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_06_11_2019_09_21_10.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
P00: GPT (00000000, 00000028) 20 KB
P01: oppodycnvbk (00000028, 00005000) 10 MB
P02: oppostanvbk (00005028, 00005000) 10 MB
P03: modemst1 (0000A028, 00000C00) 1536 KB
P04: modemst2 (0000AC28, 00000C00) 1536 KB
P05: persist (0000B828, 00010000) 32 MB
P06: opporeserve1 (0001B828, 00004000) 8 MB
P07: opporeserve2 (0001F828, 00020000) 64 MB
P08: reserve_exp1 (0003F828, 00001000) 2048 KB
P09: reserve_exp2 (00040828, 00001000) 2048 KB
P10: fsc (00041828, 00000002) 1024 b
P11: ssd (00041830, 00000010) 8 KB
P12: sbl1 (00041840, 00000400) 512 KB
P13: rpm (00041C40, 00000400) 512 KB
P14: tz (00042040, 00001000) 2048 KB
P15: devcfg (00043040, 00000200) 256 KB
P16: sbl1bak (00043240, 00000400) 512 KB
P17: rpmbak (00043640, 00000400) 512 KB
P18: tzbak (00043A40, 00001000) 2048 KB
P19: devcfgbak (00044A40, 00000200) 256 KB
P20: dsp (00044C40, 00008000) 16 MB
P21: DDR (00050000, 00000040) 32 KB
P22: fsg (00050040, 00000C00) 1536 KB
P23: sec (00050C40, 00000020) 16 KB
P24: aboot (00050C60, 00000800) 1024 KB
P25: abootbak (00051460, 00000800) 1024 KB
P26: modem (00051C60, 00040000) 128 MB
P27: dtbo (00091C60, 00004000) 8 MB
P28: vbmeta (00095C60, 00000080) 64 KB
P29: boot (00095CE0, 00020000) 64 MB
P30: recovery (000B5CE0, 00020000) 64 MB
P31: devinfo (000D5CE0, 00000800) 1024 KB
P32: splash (000D8000, 00005800) 11 MB
P33: LOGO (000DD800, 00010000) 32 MB
P34: DRIVER (000ED800, 00010000) 32 MB
P35: cache (000FD800, 00080000) 256 MB
P36: misc (0017D800, 00000800) 1024 KB
P37: keystore (0017E000, 00000400) 512 KB
P38: config (0017E400, 00000040) 32 KB
P39: oem (0017E440, 00000800) 1024 KB
P40: limits (00180000, 00000040) 32 KB
P41: mota (00184000, 00000400) 512 KB
P42: dip (00184400, 00000800) 1024 KB
P43: mdtp (00184C00, 00010000) 32 MB
P44: syscfg (00194C00, 00000400) 512 KB
P45: mcfg (00195000, 00002000) 4 MB
P46: lksecapp (00198000, 00000100) 128 KB
P47: cmnlib (00198100, 00000800) 1024 KB
P48: cmnlib64 (00198900, 00000800) 1024 KB
P49: keymaster (00199100, 00000800) 1024 KB
P50: lksecappbak (00199900, 00000100) 128 KB
P51: cmnlibbak (00199A00, 00000800) 1024 KB
P52: cmnlib64bak (0019A200, 00000800) 1024 KB
P53: keymasterbak (0019AA00, 00000800) 1024 KB
P54: apdp (0019C000, 00000200) 256 KB
P55: msadp (0019C200, 00000200) 256 KB
P56: dpo (0019C400, 00000010) 8 KB
P57: logdump (0019C410, 00020000) 64 MB
P58: vm-kystore (001BC410, 00000800) 1024 KB
P59: vm-data (001BCC10, 00005000) 10 MB
P60: hyp (001C4000, 00004000) 8 MB
P61: vm-system (001C8000, 00020000) 64 MB
P62: vm-linux (001E8000, 00010000) 32 MB
P63: system (001F8000, 006B4800) 3433 MB
P64: vendor (008AC800, 0020FB00) 1055 MB
P65: userdata (00AC0000, 0125EFDF) 9.186 GB LOG WRITTING DATA: Code:
Save to C:/Users/STARKRIMES/Desktop/OPPO/CPH1803/Samsung eMMC QE63MB_mer. nov. 6 2019_09_33_11.mpt file... Reading partition misc... Done.
Reading partition config... Done.
Reading is finished.
Repairing from file "C:/Users/STARKRIMES/Desktop/OPPO/CPH1803/CPH1803_PL_REMOVE_eMMC_STARKRIMES.srf".
Write data verification is enabled.
Writing misc partition... Done.
Writing config partition... Done.
Smart Repair is successfully complete.
Disconnected. |
