Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 10-21-2015, 16:42   #1 (permalink)
Member: 2465130
Thanks Meter: 2
Problem Octoplus Box JTAG - Box is not connected [Solved]
Hi
I have bought the new Octoplus that include the JTAG port , the box work fine with octoplus Samsung and LG but with Octoplus JTAG the program recognize the box , i see the serial , but give me always Box is not connected , i have tried to reinstall driver but without improvements......currently i'm working on windows 10 ,at the moment i don't have possibility to try on another OS
Solution?
Old 10-21-2015, 16:43   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,749
Hello.
Please contact us to Skype, or Yahoo! Messenger, we will check where can be the problem. Our contacts You can find in our profile.
Old 11-10-2015, 18:35   #3 (permalink)
Member: 1777553
Thanks Meter: 18
Dear octopus team how to activation octopus jtag. My octopus box samsung actvated. I need jtag
Old 11-10-2015, 18:56   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please contact our managers in online chat at GsmServer, they will try to help You.
Old 02-02-2016, 03:51   #5 (permalink)
Member: 785465
Thanks Meter: 7
I had problem, for fix it, just use medusa software instead Octopus JTAG, I'd never was able to run octopus jtag, but with medusa works fine. (Is the same team)
Old 02-02-2016, 05:05   #6 (permalink)
Member: 2398349
Thanks Meter: 62
I have medusa too an i have the same problem with that one too!
Sent from my iPhone using Tapatalk
Old 02-02-2016, 12:08   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Your box should be connected directly to PC (don't use USB hubs for connection), when You launch the Software. Try to use different USB ports of PC motherboard for connection.
Try to setup the Software on another, clean (with only required drivers) PC.
Old 05-13-2016, 19:47   #8 (permalink)
Member: 2254578
I have the same problem
I have the same problem I need help
Old 05-14-2016, 08:53   #9 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,339
What Box do You use exactly, Octoplus/Medusa Pro Box or old Octoplus/Medusa Box (not Pro)?
Old 05-16-2016, 00:12   #10 (permalink)
Member: 2254578
Not pro box. Please help.
Old 05-16-2016, 07:39   #11 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,339
Have You installed driver? What device exactly appears in PC Device Manager when You connecy Box to PC? Make screenshot of Device Manager and post it here.
Old 05-23-2016, 18:14   #12 (permalink)
Member: 223859
Thanks Meter: 35
disable this driver, post results
Old 05-31-2016, 21:51   #13 (permalink)
Member: 131402
Thanks Meter: 20
I'm having the same problem, the other programs work normal, but with "OctoPlus Pro JTAG software" does not detect the box, I have a box Medusa Pro, I already did card update and continue with the same problem.
Old 06-01-2016, 07:23   #14 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,339
Hi.
Most likely, Box JTAG driver is not installed. What device exactly appears in PC Device Manager when You connect Box to PC? Should appears "HSJTAG VOx100" device. Make screenshot of Device Manager and post it here.
Also try to install drivers manually from the Software folder.
Old 06-01-2016, 13:43   #15 (permalink)
Member: 131402
Thanks Meter: 20
this appearing as OctoPlus Jtag Pro V1
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.19632 seconds with 8 queries
