10-07-2018, 03:34 | #2 (permalink) |
Freak Poster Join Date: Apr 2017
Member: 2711418 Status: Offline Thanks Meter: 28 | Download the Factory files for SM-J100M from support that are compatible with your build and boot ver with the Pit file click factory repair load the files and write or use the Newest Ver of Odin add the files with the Pit and write and afterwards about 20 mins phone should boot normal |
The Following User Says Thank You to repairs4you2 For This Useful Post: |
10-09-2018, 14:02 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Accordingly to your Software log, "Smart Repair" operation was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue (problem with eMMC chip) or boot in firmware file, which You have used for repairing, are not suitable (not compatible) with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation using proper PIT file and the latest original full Samsung firmwares. |
10-12-2018, 04:53 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Here I got this file bin Be sure to remove all wires after the procedure. Hope this helps. https://www.4shared.com/rar/mjl87ifd...oot_files.html |
