10-23-2019, 01:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SM-T561 After Flash It has dead but dead boot repair done, vibration only [Solved] Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: Mobile Broadband SIM Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Sandisk eMMC DS2008 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 4501004453323030380134474F6223CD Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DS2008 Product revision : 0.1 Product serial number : (hex) 34474F62 Manufacturing date : 02/2016 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFEF8A40401F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2392064 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 3072000 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.T561XXU0AOEL Release ID :4.4.4 Device Model :SM-T561 Device Name :gtel3gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :gtel3gxx-user 4.4.4 KTU84P T561XXU0AOEL release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/DS2008_23_10_2019_01_10_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 002EE000) 1500 MB P24: hidden (00384800, 0004B000) 150 MB P25: persdata (003CF800, 00004800) 9 MB P26: userdata (003D4000, 00ABA000) 5.363 GB Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Sandisk eMMC DS2008 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 4501004453323030380134474F6223CD Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DS2008 Product revision : 0.1 Product serial number : (hex) 34474F62 Manufacturing date : 02/2016 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFEF8A40401F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2392064 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 3072000 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.T561XXU0AOEL Release ID :4.4.4 Device Model :SM-T561 Device Name :gtel3gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :gtel3gxx-user 4.4.4 KTU84P T561XXU0AOEL release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/DS2008_23_10_2019_01_10_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 002EE000) 1500 MB P24: hidden (00384800, 0004B000) 150 MB P25: persdata (003CF800, 00004800) 9 MB P26: userdata (003D4000, 00ABA000) 5.363 GB Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Sandisk eMMC DS2008 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 4501004453323030380134474F6223CD Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DS2008 Product revision : 0.1 Product serial number : (hex) 34474F62 Manufacturing date : 02/2016 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFEF8A40401F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2392064 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 3072000 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.T561XXU0AOEL Release ID :4.4.4 Device Model :SM-T561 Device Name :gtel3gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :gtel3gxx-user 4.4.4 KTU84P T561XXU0AOEL release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/DS2008_23_10_2019_01_11_03.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 002EE000) 1500 MB P24: hidden (00384800, 0004B000) 150 MB P25: persdata (003CF800, 00004800) 9 MB P26: userdata (003D4000, 00ABA000) 5.363 GB Writing EXT_CSD succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Sandisk eMMC DS2008 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 4501004453323030380134474F6223CD Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DS2008 Product revision : 0.1 Product serial number : (hex) 34474F62 Manufacturing date : 02/2016 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFEF8A40401F CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2392064 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 3072000 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.T561XXU0AOEL Release ID :4.4.4 Device Model :SM-T561 Device Name :gtel3gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :gtel3gxx-user 4.4.4 KTU84P T561XXU0AOEL release-keys Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/DS2008_23_10_2019_01_11_38.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 002EE000) 1500 MB P24: hidden (00384800, 0004B000) 150 MB P25: persdata (003CF800, 00004800) 9 MB P26: userdata (003D4000, 00ABA000) 5.363 GB Selected pit file: D:/Firmware/Samsung/T561/T561XXU0AOEL_OXY0AOEL/GTEL3G_EUR_OPEN.pit Open file "D:/Firmware/Samsung/T561/T561XXU0AOEL_OXY0AOEL/BL_T561XXU0AOEL_CL549358_QB5085847_REV07_user_low_ ship.tar". Open file "D:/Firmware/Samsung/T561/T561XXU0AOEL_OXY0AOEL/AP_T561XXU0AOEL_CL549358_QB5085847_REV07_user_low_ ship.tar". Open file "D:/Firmware/Samsung/T561/T561XXU0AOEL_OXY0AOEL/CP_T561XXU0AOEL_CL549358_QB5085847_REV07_user_low_ ship.tar". Open file "D:/Firmware/Samsung/T561/T561XXU0AOEL_OXY0AOEL/CSC_OXY_T561OXY0AOEL_CL549358_QB5085847_REV07_user _low_ship.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition wfixnv2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition PARAM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CSC... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.7.7; FW: 1.24. Disconnected. |
10-23-2019, 08:26 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. If You've already repaired your device, that try to reflash it with stock firmware, if the problem will still remain, most likely your device has some HW issue |
10-23-2019, 11:50 | #3 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Nothing have H/W Issue, it's had wrong flash problem. When flash the correct firmware now tab become okay Odin Log:- Code: T561XXU0APA2_T561OJV0AOK2_T561JVU0APB1_XFV_4.4.4 <ID:0/005> Added!! <ID:0/005> Removed!! <ID:0/005> Added!! <ID:0/005> Odin engine v(ID:3.1301).. <ID:0/005> File analysis.. <ID:0/005> Total Binary size: 1235 M <ID:0/005> SetupConnection.. <ID:0/005> Initialzation.. <ID:0/005> Get PIT for mapping.. <ID:0/005> Firmware update start.. <ID:0/005> NAND Write Start!! <ID:0/005> SingleDownload. <ID:0/005> spl.img <ID:0/005> sboot.bin <ID:0/005> sboot2.bin <ID:0/005> boot.img <ID:0/005> recovery.img <ID:0/005> system.img <ID:0/005> SPRDCP.img <ID:0/005> SPRDDSP.img <ID:0/005> cache.img <ID:0/005> hidden.img <ID:0/005> RQT_CLOSE !! <ID:0/005> RES OK !! <ID:0/005> Removed!! <ID:0/005> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
10-23-2019, 12:33 | #4 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Now face the IMEI null problem, software showing everything has been repaired success but IMEI still null. Code: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-T561 Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-T561 Firmware compiled date: Mon Jan 25 22:12:02 KST 2016 PDA version: T561XXU0APA2 CSC version: T561OJV0AOK2 SW version: T561JVU0APB1 Build number: Phone SN: R52G70EJ0RX Android version: 4.4.4 (KTU84P) Sales code: XSG Country: UAE HW platform: sc8830 HW Chip: SC7730SE HW Modem: SC7730SE Security patch level: 2016-02-01 SIM 1 status: not ready Codename: gtel3gxx Checking Root: Phone is Rooted. Old IMEI A: Unknown New IMEI A: 3560098777777722 Repairing IMEI. Please wait... Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.8.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-T561 Operation: Repair Network Detected phone model: SM-T561 Firmware compiled date: Mon Jan 25 22:12:02 KST 2016 PDA version: T561XXU0APA2 CSC version: unknown SW version: T561JVU0APB1 Build number: Phone SN: R52G70EJ0RX Android version: 4.4.4 (KTU84P) Sales code: XSG Country: UAE HW platform: sc8830 HW Chip: SC7730SE HW Modem: SC7730SE Security patch level: 2016-02-01 SIM 1 status: not ready Codename: gtel3gxx Checking Root: Phone is Rooted. Detecting MODEM type...OK Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! Network is successfully repaired. Performed by 2.8.4 Software version. |
