04-30-2020, 00:27 | #1 (permalink) | |
Junior Member Join Date: Jan 2019 Location: Brazil
Member: 2886646 Status: Offline Thanks Meter: 0 | Help: ERROR[013] [Answered] Could anyone help? Thankful! Quote:
05-01-2020, 06:09 | #3 (permalink) |
Member: 2886646 Status: Offline Thanks Meter: 0 | Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 10 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420749EDCF009469 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 49EDCF00 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_30_04_2020_23_37_22.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: spare1 (00001C00, 00002400) 4.5 MB P03: misc2 (00004000, 00004000) 8 MB P04: ftm (00008000, 00004000) 8 MB P05: nvram (0000C000, 00002800) 5 MB P06: spare2 (0000E800, 00001800) 3072 KB P07: protect1 (00010000, 00004000) 8 MB P08: protect2 (00014000, 00004000) 8 MB P09: lk (00018000, 00000800) 1024 KB P10: lk2 (00018800, 00000800) 1024 KB P11: laf (00019000, 0000E000) 28 MB P12: para (00027000, 00000400) 512 KB P13: boot (00027400, 00008C00) 17.5 MB P14: recovery (00030000, 00009800) 19 MB P15: recoverybak (00039800, 00009800) 19 MB P16: logo (00043000, 00004000) 8 MB P17: lo_bak_go (00047000, 00004000) 8 MB P18: expdb (0004B000, 00005000) 10 MB P19: seccfg (00050000, 00004000) 8 MB P20: oemkeystore (00054000, 00004000) 8 MB P21: secro (00058000, 00003000) 6 MB P22: spare3 (0005B000, 00001000) 2048 KB P23: keystore (0005C000, 00004000) 8 MB P24: tee1 (00060000, 00002800) 5 MB P25: tee2 (00062800, 00002800) 5 MB P26: eksst (00065000, 00000400) 512 KB P27: encrypt (00065400, 00000400) 512 KB P28: spare4 (00065800, 00002800) 5 MB P29: persist_lg (00068000, 00004000) 8 MB P30: mpt (0006C000, 0000B000) 22 MB P31: lgfota (00077000, 00005000) 10 MB P32: rct (0007C000, 00000800) 1024 KB P33: factory (0007C800, 0001C000) 56 MB P34: efuse (00098800, 00000400) 512 KB P35: spare5 (00098C00, 00003400) 6.5 MB P36: persist (0009C000, 00018000) 48 MB P37: nvcfg (000B4000, 00004000) 8 MB P38: nvdata (000B8000, 00010000) 32 MB P39: metadata (000C8000, 00010000) 32 MB P40: md1img (000D8000, 0000C000) 24 MB P41: md1dsp (000E4000, 00002000) 4 MB P42: md1arm7 (000E6000, 00001800) 3072 KB P43: md3img (000E7800, 00002800) 5 MB P44: cust (000EA000, 00032000) 100 MB P45: frp (0011C000, 00004000) 8 MB P46: system (00120000, 007C0000) 3968 MB P47: cache (008E0000, 00100000) 512 MB P48: OP (009E0000, 002A8000) 1360 MB P49: userdata (00C88000, 0108EC00) 8.279 GB P50: flashinfo (FFFF0084, FFFFFFFF00017F7D) 1.718e+10 GB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_nvdata_0xb8000_0x10000_30_04_2020_23_37_22. bin file... Reading. Please wait... Done. Elapsed time 00:00:30 SW: 2.0.9; FW: 1.24. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... Cancelled SW: 2.0.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 4 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420749EDCF009469 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 49EDCF00 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_30_04_2020_23_39_13.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 4 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420749EDCF009469 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 49EDCF00 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_30_04_2020_23_39_19.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... Cancelled SW: 2.0.9; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420749EDCF009469 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 49EDCF00 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_30_04_2020_23_40_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. Erasing. Please wait... error! ERROR[013]: Erase error. Attempting to erase... Cancelled SW: 2.0.9; FW: 1.24. Disconnected. |
05-01-2020, 17:19 | #5 (permalink) |
Member: 2886646 Status: Offline Thanks Meter: 0 | I am trying to repair the boot of lg m250ds and a g5s xt1792 and this error always appears; ERROR [013]: Erase error. Attempting to erase ... already confingurei in divaras voltage, 2.0, 2.8 .., speed and always gives this error. |
05-03-2020, 01:16 | #7 (permalink) |
Member: 2886646 Status: Offline Thanks Meter: 0 | Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 58728448 Size : 28.00 GB (28676.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420749EDCF009469 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 49EDCF00 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x40) 01000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x1F Part setting completed: 0x1 GP partition 1 size : 128 MB GP partition 2 size : 128 MB GP partition 3 size : 128 MB GP partition 4 size : 128 MB Enhanced area size : (0x7800000) 120 MB Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_02_05_2020_21_13_38.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: spare1 (00001C00, 00002400) 4.5 MB P03: misc2 (00004000, 00004000) 8 MB P04: ftm (00008000, 00004000) 8 MB P05: nvram (0000C000, 00002800) 5 MB P06: spare2 (0000E800, 00001800) 3072 KB P07: protect1 (00010000, 00004000) 8 MB P08: protect2 (00014000, 00004000) 8 MB P09: lk (00018000, 00000800) 1024 KB P10: lk2 (00018800, 00000800) 1024 KB P11: laf (00019000, 0000E000) 28 MB P12: para (00027000, 00000400) 512 KB P13: boot (00027400, 00008C00) 17.5 MB P14: recovery (00030000, 00009800) 19 MB P15: recoverybak (00039800, 00009800) 19 MB P16: logo (00043000, 00004000) 8 MB P17: lo_bak_go (00047000, 00004000) 8 MB P18: expdb (0004B000, 00005000) 10 MB P19: seccfg (00050000, 00004000) 8 MB P20: oemkeystore (00054000, 00004000) 8 MB P21: secro (00058000, 00003000) 6 MB P22: spare3 (0005B000, 00001000) 2048 KB P23: keystore (0005C000, 00004000) 8 MB P24: tee1 (00060000, 00002800) 5 MB P25: tee2 (00062800, 00002800) 5 MB P26: eksst (00065000, 00000400) 512 KB P27: encrypt (00065400, 00000400) 512 KB P28: spare4 (00065800, 00002800) 5 MB P29: persist_lg (00068000, 00004000) 8 MB P30: mpt (0006C000, 0000B000) 22 MB P31: lgfota (00077000, 00005000) 10 MB P32: rct (0007C000, 00000800) 1024 KB P33: factory (0007C800, 0001C000) 56 MB P34: efuse (00098800, 00000400) 512 KB P35: spare5 (00098C00, 00003400) 6.5 MB P36: persist (0009C000, 00018000) 48 MB P37: nvcfg (000B4000, 00004000) 8 MB P38: nvdata (000B8000, 00010000) 32 MB P39: metadata (000C8000, 00010000) 32 MB P40: md1img (000D8000, 0000C000) 24 MB P41: md1dsp (000E4000, 00002000) 4 MB P42: md1arm7 (000E6000, 00001800) 3072 KB P43: md3img (000E7800, 00002800) 5 MB P44: cust (000EA000, 00032000) 100 MB P45: frp (0011C000, 00004000) 8 MB P46: system (00120000, 007C0000) 3968 MB P47: cache (008E0000, 00100000) 512 MB P48: OP (009E0000, 002A8000) 1360 MB P49: userdata (00C88000, 0108EC00) 8.279 GB P50: flashinfo (FFFF0084, FFFFFFFF00017F7D) 1.718e+10 GB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_nvdata_0xb8000_0x10000_02_05_2020_21_13_39. bin file... Reading. Please wait... Done. Elapsed time 00:00:13 SW: 2.0.9; FW: 1.24. Opening C:/Users/Pc02/Downloads/Compressed/M250ds10f_00_OPEN_SCA_DS_OP_0823.kdz/M250ds10f_00_OPEN_SCA_DS_OP_0823.kdz file... Write data verification is enabled. Writing. Please wait... Switch error!!! Writing partition preloader... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 58728448 Size : 28.00 GB (28676.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420749EDCF009469 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 49EDCF00 Manufacturing date : 09/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x40) 01000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x1F Part setting completed: 0x1 GP partition 1 size : 128 MB GP partition 2 size : 128 MB GP partition 3 size : 128 MB GP partition 4 size : 128 MB Enhanced area size : (0x7800000) 120 MB Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_02_05_2020_21_14_36.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: spare1 (00001C00, 00002400) 4.5 MB P03: misc2 (00004000, 00004000) 8 MB P04: ftm (00008000, 00004000) 8 MB P05: nvram (0000C000, 00002800) 5 MB P06: spare2 (0000E800, 00001800) 3072 KB P07: protect1 (00010000, 00004000) 8 MB P08: protect2 (00014000, 00004000) 8 MB P09: lk (00018000, 00000800) 1024 KB P10: lk2 (00018800, 00000800) 1024 KB P11: laf (00019000, 0000E000) 28 MB P12: para (00027000, 00000400) 512 KB P13: boot (00027400, 00008C00) 17.5 MB P14: recovery (00030000, 00009800) 19 MB P15: recoverybak (00039800, 00009800) 19 MB P16: logo (00043000, 00004000) 8 MB P17: lo_bak_go (00047000, 00004000) 8 MB P18: expdb (0004B000, 00005000) 10 MB P19: seccfg (00050000, 00004000) 8 MB P20: oemkeystore (00054000, 00004000) 8 MB P21: secro (00058000, 00003000) 6 MB P22: spare3 (0005B000, 00001000) 2048 KB P23: keystore (0005C000, 00004000) 8 MB P24: tee1 (00060000, 00002800) 5 MB P25: tee2 (00062800, 00002800) 5 MB P26: eksst (00065000, 00000400) 512 KB P27: encrypt (00065400, 00000400) 512 KB P28: spare4 (00065800, 00002800) 5 MB P29: persist_lg (00068000, 00004000) 8 MB P30: mpt (0006C000, 0000B000) 22 MB P31: lgfota (00077000, 00005000) 10 MB P32: rct (0007C000, 00000800) 1024 KB P33: factory (0007C800, 0001C000) 56 MB P34: efuse (00098800, 00000400) 512 KB P35: spare5 (00098C00, 00003400) 6.5 MB P36: persist (0009C000, 00018000) 48 MB P37: nvcfg (000B4000, 00004000) 8 MB P38: nvdata (000B8000, 00010000) 32 MB P39: metadata (000C8000, 00010000) 32 MB P40: md1img (000D8000, 0000C000) 24 MB P41: md1dsp (000E4000, 00002000) 4 MB P42: md1arm7 (000E6000, 00001800) 3072 KB P43: md3img (000E7800, 00002800) 5 MB P44: cust (000EA000, 00032000) 100 MB P45: frp (0011C000, 00004000) 8 MB P46: system (00120000, 007C0000) 3968 MB P47: cache (008E0000, 00100000) 512 MB P48: OP (009E0000, 002A8000) 1360 MB P49: userdata (00C88000, 0108EC00) 8.279 GB P50: flashinfo (FFFF0084, FFFFFFFF00017F7D) 1.718e+10 GB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_nvdata_0xb8000_0x10000_02_05_2020_21_14_36. bin file... Reading. Please wait... Done. Elapsed time 00:00:19 SW: 2.0.9; FW: 1.24. Opening C:/Users/Pc02/Downloads/Compressed/M250ds10f_00_OPEN_SCA_DS_OP_0823.kdz/M250ds10f_00_OPEN_SCA_DS_OP_0823.kdz file... Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition preloader... Done. Switched to user area. Writing partition pgpt... Done. Writing partition lk... Done. Writing partition lk2... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... ERROR[012]: Write error. At sector 0 Disconnected. |
05-20-2020, 03:35 | #11 (permalink) |
Member: 2886646 Status: Offline Thanks Meter: 0 | Hello friends, I'm back here because I don't know but what to do. people help the support, because you can never make a device in that box. k10 m250ds, k10 430tv, sm-g530, moto g2 xt169, moto g5s xt1792. and other phones, give the following message. P: ERROR [012]: The server being used does not support ECC. R: The. It doesn't have to come. It's here for compatibility. B. Interior error. Contact the manufacturers (present the “Medusa.log” file). or Q: ERROR [013]: Current server does not support writing with ECC. THE: The. Should not occur. Kept in terms of compatibility. B. Internal error. Contact the developers (provide “Medusa.log” log file). This is what has in the faqs, on the website, error 12, b) says that we must contact the manufacturer. no longer from Personnel support help. Thankful! |
05-20-2020, 20:34 | #12 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | just relax box is working great. sure you have emmc fault or you do something wrong like wiring here is successfull LG M250E eMMC read done Code: Welcome to Octoplus Pro JTAG Software version 1.6.7. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420D07CF977B2453 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 7CF977B Manufacturing date : 02/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1179648 Number of sectors : 8126464 Device Manufacturer :lge Device Platform :mt6750 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-M250 Device Name :mlv5_global_com Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :mlv5_global_com-user 7.0 NRD90U 17081003172df release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_08_09_2018_21_27_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: spare1 (00001C00, 00002400) 4.5 MB P03: misc2 (00004000, 00004000) 8 MB P04: ftm (00008000, 00004000) 8 MB P05: nvram (0000C000, 00002800) 5 MB P06: spare2 (0000E800, 00001800) 3072 KB P07: protect1 (00010000, 00004000) 8 MB P08: protect2 (00014000, 00004000) 8 MB P09: lk (00018000, 00000800) 1024 KB P10: lk2 (00018800, 00000800) 1024 KB P11: laf (00019000, 0000E000) 28 MB P12: para (00027000, 00000400) 512 KB P13: boot (00027400, 00008C00) 17.5 MB P14: recovery (00030000, 00009800) 19 MB P15: recoverybak (00039800, 00009800) 19 MB P16: logo (00043000, 00004000) 8 MB P17: lo_bak_go (00047000, 00004000) 8 MB P18: expdb (0004B000, 00005000) 10 MB P19: seccfg (00050000, 00004000) 8 MB P20: oemkeystore (00054000, 00004000) 8 MB P21: secro (00058000, 00003000) 6 MB P22: spare3 (0005B000, 00001000) 2048 KB P23: keystore (0005C000, 00004000) 8 MB P24: tee1 (00060000, 00002800) 5 MB P25: tee2 (00062800, 00002800) 5 MB P26: eksst (00065000, 00000400) 512 KB P27: encrypt (00065400, 00000400) 512 KB P28: spare4 (00065800, 00002800) 5 MB P29: persist_lg (00068000, 00004000) 8 MB P30: mpt (0006C000, 0000B000) 22 MB P31: lgfota (00077000, 00005000) 10 MB P32: rct (0007C000, 00000800) 1024 KB P33: factory (0007C800, 0001C000) 56 MB P34: efuse (00098800, 00000400) 512 KB P35: spare5 (00098C00, 00003400) 6.5 MB P36: persist (0009C000, 00018000) 48 MB P37: nvcfg (000B4000, 00004000) 8 MB P38: nvdata (000B8000, 00010000) 32 MB P39: metadata (000C8000, 00010000) 32 MB P40: md1img (000D8000, 0000C000) 24 MB P41: md1dsp (000E4000, 00002000) 4 MB P42: md1arm7 (000E6000, 00001800) 3072 KB P43: md3img (000E7800, 00002800) 5 MB P44: cust (000EA000, 00032000) 100 MB P45: frp (0011C000, 00004000) 8 MB P46: system (00120000, 007C0000) 3968 MB P47: cache (008E0000, 00100000) 512 MB P48: OP (009E0000, 00038000) 112 MB P49: userdata (00A18000, 012FEC00) 9.498 GB P50: flashinfo (01D16C00, 00008000) 16 MB |
05-22-2020, 00:31 | #13 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | For What you have modified boot config and Enhanced attribut Quote:
And for every connect you change bus speed ? For What you change it every Time ! | |
