05-09-2020, 20:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2013 Location: usa
Member: 1968527 Status: Offline Thanks Meter: 31 | smart tv medusa coonect but... [Answered] Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 4294967295 Size : 2048.00 GB (2097152.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4841473265050352473A6CA3EB Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.3 Product serial number : (hex) 52473A6C Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 130560 Kbytes Boot1 size : 32640 Kbytes Boot2 size : 32640 Kbytes RPMB size : 32640 Kbytes Partition config : (0xFF) 11111111 Boot partition enable : User area Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0xFF) 11111111 Boot bus width : Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : RST_n function : (0x03) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4261674496 Kbytes Partitions attribute : 0xFF Part setting completed: 0xFF GP partition 1 size : 255.5 MB GP partition 2 size : 255.5 MB GP partition 3 size : 255.5 MB GP partition 4 size : 255.5 MB Enhanced area size : (0xFF80000) 255.5 MB Enhanced area start : (0xFFFFFE00) 4096 MB Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_09_05_2020_21_14_11.bin. Connect successful. -------------------------------------------------------------- when i change volt more them 2. software restare and box disconnect:-( |
The Following User Says Thank You to selve1411 For This Useful Post: |
05-12-2020, 07:49 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Quote:
05-19-2020, 07:34 | #3 (permalink) | |
Member: 1968527 Status: Offline Thanks Meter: 31 | Quote:
Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4841473265050352473A6CA3EB Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.3 Product serial number : (hex) 52473A6C Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_18_05_2020_17_47_31.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. The same area. Opening C:/Users/sara/Desktop/new/EMMC_T16GE2_ROM1_ 36mhz 000000000000_0003AB400000.bin file... Write data verification is enabled. Writing. Please wait... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. | |
