05-05-2016, 19:55 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2188261 Status: Offline Thanks Meter: 13 | LG H950 Successful Unlock Platform: LG Qualcomm Selected port: COM4 Selected model: H950 Reading info... Model ID: LG-H950 IMEI: Android version: 5.1.1 Battery level: 81% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model LGH950AT: ÿd at port COM4 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H950__05-05-2016_14-42-58.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "H950__05-05-2016_14-50-10.SEC" Switching to Normal mode... Performed by 2.2.8 software version. |
05-20-2016, 15:11 | #3 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | 20/05/2016 11:08:53 > Checking data...20/05/2016 11:08:54 > OK 20/05/2016 11:08:54 > Platform: LG Qualcomm 20/05/2016 11:08:54 > Selected port: COM56 20/05/2016 11:08:54 > Selected model: H950 20/05/2016 11:08:54 > Reading info... 20/05/2016 11:08:57 > Model ID: LG-H950 20/05/2016 11:08:57 > IMEI: 357505-06-046182-6 20/05/2016 11:08:57 > Android version: 5.0.1 20/05/2016 11:08:57 > Battery level: 89% 20/05/2016 11:09:01 > Trying to enable Diagnostics ports... 20/05/2016 11:09:01 > Initializing ADB...20/05/2016 11:09:02 > OK 20/05/2016 11:09:02 > Waiting for phone...20/05/2016 11:09:03 > OK 20/05/2016 11:09:04 > Diagnostics ports are enbled! 20/05/2016 11:09:04 > Switching to Serial Port... 20/05/2016 11:09:31 > Failed! 20/05/2016 11:09:31 > Trying to enable Diagnostics ports... 20/05/2016 11:09:31 > Checking root access... 20/05/2016 11:09:32 > Phone is not rooted. 20/05/2016 11:09:33 > Please, root the phone manually! 20/05/2016 11:09:33 > Performed by 2.2.7 software version. |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
05-20-2016, 16:05 | #4 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | 20/05/2016 10:33:08 > Switching to Normal mode... 20/05/2016 10:33:52 > Trying to enable Diagnostics ports... 20/05/2016 10:33:52 > Initializing ADB...20/05/2016 10:33:53 > OK 20/05/2016 10:33:53 > Waiting for phone... 20/05/2016 10:33:53 > Please, reconnect phone, enable USB debugging, and try again. 20/05/2016 10:33:53 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. |
05-20-2016, 17:14 | #7 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | 20/05/2016 10:24:14 > Checking data...20/05/2016 10:24:14 > OK 20/05/2016 10:24:14 > Platform: LG Qualcomm 20/05/2016 10:24:14 > Selected port: COM44 20/05/2016 10:24:14 > Selected model: H950 20/05/2016 10:24:14 > Reading info... 20/05/2016 10:24:17 > Model ID: LG-H950 20/05/2016 10:24:18 > IMEI: 357505-06-046182-6 20/05/2016 10:24:18 > Android version: 5.0.1 20/05/2016 10:24:18 > Battery level: 99% 20/05/2016 10:24:18 > Mode: Normal 20/05/2016 10:24:18 > Firmware compiled date: Feb 18 2015 20/05/2016 10:24:18 > Firmware compiled time: 17:00:00 20/05/2016 10:24:18 > Firmware released date: Mar 20 2015 20/05/2016 10:24:18 > Firmware released time: 17:04:52 20/05/2016 10:24:18 > SW Version: MPSS.BO.2.0.1.c3.2-00017-M8994FAAAANAZM-1 20/05/2016 10:24:18 > IMEI: 357505-06-046182-6 20/05/2016 10:24:18 > SPC: 000000 20/05/2016 10:24:18 > Unlocking... 20/05/2016 10:24:19 > Reading QCN... 20/05/2016 10:24:19 > Send SPC...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading Mobile Property...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading Feature Mask...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading Roaming List 0...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading NV_Numbered Items...20/05/2016 10:26:38 > OK 20/05/2016 10:26:38 > Reading NV_Numbered SIM1 Items...20/05/2016 10:29:05 > OK 20/05/2016 10:29:05 > Reading NV_Numbered SIM2 Items...20/05/2016 10:31:35 > OK 20/05/2016 10:31:35 > Reading NV Items...20/05/2016 10:31:41 > OK 20/05/2016 10:31:41 > Reading EFS...20/05/2016 10:31:42 > OK 20/05/2016 10:31:42 > Reading Provisioning Items...20/05/2016 10:31:52 > OK 20/05/2016 10:31:52 > Reading QCN done! 20/05/2016 10:31:52 > Backup saved to "H950_357505060461826_20-05-2016_10-24-19.qcn" 20/05/2016 10:31:52 > Do you want to create security backup? 20/05/2016 10:31:56 > Switching to Download mode...20/05/2016 10:32:23 > OK 20/05/2016 10:32:23 > Initializing flash...20/05/2016 10:32:25 > OK 20/05/2016 10:32:25 > Reading partition...20/05/2016 10:32:27 > OK 20/05/2016 10:32:27 > Reading security area...20/05/2016 10:33:08 > OK 20/05/2016 10:33:08 > Backup saved to "H950_357505060461826_20-05-2016_10-32-27.SEC" 20/05/2016 10:33:08 > Switching to Normal mode... 20/05/2016 10:33:52 > Trying to enable Diagnostics ports... 20/05/2016 10:33:52 > Initializing ADB...20/05/2016 10:33:53 > OK 20/05/2016 10:33:53 > Waiting for phone... 20/05/2016 10:33:53 > Please, reconnect phone, enable USB debugging, and try again. 20/05/2016 10:33:53 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. 20/05/2016 10:34:23 > Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button 20/05/2016 10:34:31 > Trying to enable Diagnostics ports... 20/05/2016 10:34:31 > Initializing ADB...20/05/2016 10:34:32 > OK 20/05/2016 10:34:32 > Waiting for phone... 20/05/2016 10:34:32 > Please, reconnect phone, enable USB debugging, and try again. 20/05/2016 10:34:32 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. 20/05/2016 10:35:04 > Performed by 2.2.7 software version. |
05-20-2016, 17:16 | #8 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Pls how can i unlock without rooting 20/05/2016 11:17:50 > Checking data...20/05/2016 11:17:50 > OK 20/05/2016 11:17:50 > Platform: LG Qualcomm 20/05/2016 11:17:50 > Selected port: COM56 20/05/2016 11:17:50 > Selected model: H950 20/05/2016 11:17:50 > Reading info... 20/05/2016 11:17:53 > Model ID: LG-H950 20/05/2016 11:17:53 > IMEI: 357505-06-046182-6 20/05/2016 11:17:53 > Android version: 5.0.1 20/05/2016 11:17:55 > Battery level: 87% 20/05/2016 11:17:58 > Trying to enable Diagnostics ports... 20/05/2016 11:17:58 > Initializing ADB...20/05/2016 11:17:59 > OK 20/05/2016 11:17:59 > Waiting for phone...20/05/2016 11:18:01 > OK 20/05/2016 11:18:02 > Diagnostics ports are enbled! 20/05/2016 11:18:02 > Switching to Serial Port... 20/05/2016 11:18:30 > Failed! 20/05/2016 11:18:30 > Trying to enable Diagnostics ports... 20/05/2016 11:18:30 > Checking root access... 20/05/2016 11:18:31 > Phone is not rooted. 20/05/2016 11:18:32 > Please, root the phone manually! 20/05/2016 11:18:32 > Performed by 2.2.7 software version. |
05-21-2016, 06:35 | #11 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Initially when connected phone in charging mode to pc in normal mode, i had com port(com44) installed and was performing unlocking but when phone switched to download mode to backup security files on phone upon the unlocking process, the com port(com44) disappeared when phone switched back to normal mode. This is the log 20/05/2016 10:24:14 > -------------------------------------------------------------------------------- 20/05/2016 10:24:14 > Checking data...20/05/2016 10:24:14 > OK 20/05/2016 10:24:14 > Platform: LG Qualcomm 20/05/2016 10:24:14 > Selected port: COM44 20/05/2016 10:24:14 > Selected model: H950 20/05/2016 10:24:14 > Reading info... 20/05/2016 10:24:17 > Model ID: LG-H950 20/05/2016 10:24:18 > IMEI: 357505-06-046182-6 20/05/2016 10:24:18 > Android version: 5.0.1 20/05/2016 10:24:18 > Battery level: 99% 20/05/2016 10:24:18 > Mode: Normal 20/05/2016 10:24:18 > Firmware compiled date: Feb 18 2015 20/05/2016 10:24:18 > Firmware compiled time: 17:00:00 20/05/2016 10:24:18 > Firmware released date: Mar 20 2015 20/05/2016 10:24:18 > Firmware released time: 17:04:52 20/05/2016 10:24:18 > SW Version: MPSS.BO.2.0.1.c3.2-00017-M8994FAAAANAZM-1 20/05/2016 10:24:18 > IMEI: 357505-06-046182-6 20/05/2016 10:24:18 > SPC: 000000 20/05/2016 10:24:18 > Unlocking... 20/05/2016 10:24:19 > Reading QCN... 20/05/2016 10:24:19 > Send SPC...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading Mobile Property...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading Feature Mask...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading Roaming List 0...20/05/2016 10:24:19 > OK 20/05/2016 10:24:19 > Reading NV_Numbered Items...20/05/2016 10:26:38 > OK 20/05/2016 10:26:38 > Reading NV_Numbered SIM1 Items...20/05/2016 10:29:05 > OK 20/05/2016 10:29:05 > Reading NV_Numbered SIM2 Items...20/05/2016 10:31:35 > OK 20/05/2016 10:31:35 > Reading NV Items...20/05/2016 10:31:41 > OK 20/05/2016 10:31:41 > Reading EFS...20/05/2016 10:31:42 > OK 20/05/2016 10:31:42 > Reading Provisioning Items...20/05/2016 10:31:52 > OK 20/05/2016 10:31:52 > Reading QCN done! 20/05/2016 10:31:52 > Backup saved to "H950_357505060461826_20-05-2016_10-24-19.qcn" 20/05/2016 10:31:52 > Do you want to create security backup? 20/05/2016 10:31:56 > Switching to Download mode...20/05/2016 10:32:23 > OK 20/05/2016 10:32:23 > Initializing flash...20/05/2016 10:32:25 > OK 20/05/2016 10:32:25 > Reading partition...20/05/2016 10:32:27 > OK 20/05/2016 10:32:27 > Reading security area...20/05/2016 10:33:08 > OK 20/05/2016 10:33:08 > Backup saved to "H950_357505060461826_20-05-2016_10-32-27.SEC" 20/05/2016 10:33:08 > Switching to Normal mode... 20/05/2016 10:33:52 > Trying to enable Diagnostics ports... 20/05/2016 10:33:52 > Initializing ADB...20/05/2016 10:33:53 > OK 20/05/2016 10:33:53 > Waiting for phone... 20/05/2016 10:33:53 > Please, reconnect phone, enable USB debugging, and try again. 20/05/2016 10:33:53 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. 20/05/2016 10:34:23 > Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button 20/05/2016 10:34:31 > Trying to enable Diagnostics ports... 20/05/2016 10:34:31 > Initializing ADB...20/05/2016 10:34:32 > OK 20/05/2016 10:34:32 > Waiting for phone... 20/05/2016 10:34:32 > Please, reconnect phone, enable USB debugging, and try again. 20/05/2016 10:34:32 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. 20/05/2016 10:35:04 > Performed by 2.2.7 software version. Since i was no longer getting the com44 when charging mode was selected in normal mode on the same usb port, I had to connect phone and select MTP mode and this time i had com56 but phone failed to open serial port upon operation and now the software is asking the phone to be rooted. Here is the log 20/05/2016 10:56:01 > Checking data...20/05/2016 10:56:03 > OK 20/05/2016 10:56:03 > Platform: LG Qualcomm 20/05/2016 10:56:03 > Selected port: COM56 20/05/2016 10:56:03 > Selected model: H950 20/05/2016 10:56:03 > Reading info... 20/05/2016 10:56:06 > Model ID: LG-H950 20/05/2016 10:56:06 > IMEI: 357505-06-046182-6 20/05/2016 10:56:06 > Android version: 5.0.1 20/05/2016 10:56:06 > Battery level: 94% 20/05/2016 10:56:09 > Trying to enable Diagnostics ports... 20/05/2016 10:56:09 > Initializing ADB...20/05/2016 10:56:10 > OK 20/05/2016 10:56:11 > Waiting for phone...20/05/2016 10:56:18 > OK 20/05/2016 10:56:19 > Diagnostics ports are enbled! 20/05/2016 10:56:19 > Switching to Serial Port... 20/05/2016 10:56:46 > Failed! 20/05/2016 10:56:46 > Trying to enable Diagnostics ports... 20/05/2016 10:56:46 > Checking root access... 20/05/2016 10:56:48 > Phone is not rooted. 20/05/2016 10:56:48 > Please, root the phone manually! 20/05/2016 10:56:48 > Performed by 2.2.7 software version. Pls help |
05-21-2016, 11:42 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,431 | Please, install the latest Software version and repeat operation again, then post here full Software log. |
05-22-2016, 09:24 | #13 (permalink) | |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Quote:
05-22-2016, 14:10 | #14 (permalink) | |
Member: 2188261 Status: Offline Thanks Meter: 13 | Quote:
The Following User Says Thank You to hulksjeep For This Useful Post: |
