04-20-2015, 15:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | lg d820 flash errore Code: Welcome to Octoplus/Octopus Box LG Software version 1.9.1 Checking data...OK Platform: LG Qualcomm Selected port: COM232 Selected model: D820 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LGD820 SW version: LGD820AT-00-V10d-NXS-XX-DEC-11-2013-KOT49H-USER- 16G+0 LAF Version: 1.0 Product ID: HD60S140219001842 IMEI: 358239-05-921691-3 Target operator: ro.build.target_coun Hardware: rev_11 Battery level: 81% Opening "LGD820AT-00-V10a-NXS-OCT-09-2013-KQS81M-USER-16G+ 0.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...Failed! |
04-20-2015, 15:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the state of your phone? What is the problem with it exactly? Check your PM, we have sent You test Software version. Try to perform "Write Firmware" with it and post results here. Last edited by Octopus box; 04-20-2015 at 15:54. |
04-21-2015, 06:55 | #4 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | it stop on 97/ flashing Code: Welcome to Octoplus/Octopus Box LG Software version 1.9.1.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM232 Selected model: D820 Reading info...OK Mode: Emergency Initializing flash...OK Model ID: LGD820 SW version: LGD820AT-00-V10d-NXS-XX-DEC-11-2013-KOT49H-USER- 16G+0 LAF Version: 1.0 Product ID: HD60S140219001842 IMEI: 358239-05-921691-3 Target operator: ro.build.target_coun Hardware: rev_11 Battery level: 93% Opening "LGD820AT-00-V10a-NXS-OCT-09-2013-KQS81M-USER-16G+ 0.oct"...OK Setting options...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing sbl1b...OK Writing tzb...OK Writing rpmb...OK Writing abootb...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...OK Writing cache...OK Writing BackupGPT...OK Reading partition...Failed! Error code: ZXLCALSZXC |
04-21-2015, 07:47 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-flash again. If the problem is still the same, most likely, it has HW issue. Also, You can try to find another firmware, convert and write it. Currently we have only this one firmware. |
