11-07-2017, 08:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Gsmhosting Forum
Member: 1832100 Status: Offline Thanks Meter: 63 | LG H845 G5 After flash "Factory Reset Status 3" First Phone Problem in IMEI Missing . I try to flash with Octopus Box Flashing Success After Flash Stuck on "Factory Reset Status 3" [IMG]**************************************/images?q=tbn:ANd9GcT4qwLvmCYsmx7MjP-y-_KpUF9AG600fB1ptrwDZ3fzRTsrjPTA[/IMG] First Flash this firmware on Box Support site : LGH845AT-00-V20e-CIS-XX-MAY-02-2017+0 Then Try to This Firmware : H845 20c_00_OPEN_ESA_DS_OP_0323 But After Same Problem How to Solve This Problem |
11-07-2017, 08:47 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Hello. Please, try to perform Hard Reset via keys' combination. Last edited by Octopus box; 11-07-2017 at 09:44. |
11-07-2017, 16:55 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please, try to connect your phone as H443 and perform Factory Reset operation. |
11-08-2017, 08:21 | #5 (permalink) | |
Member: 1832100 Status: Offline Thanks Meter: 63 | Quote:
Here is Log : Checking data...OK Platform: LG Qualcomm Selected port: COM146 Selected model: H443 Reading info... Model ID: LG-H845 Incompatible model ID! IMEI: 357979-07-118221-0 Android version: 7.0 Battery level: 81% SW Version: H84520c Mode: Emergency Initializing flash...OK SW version: LGH845AT-00-V20c-AME-XX-MAR-23-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: BS03S160523002408 IMEI: 357979-07-118221-0 Target operator: GLOBAL Hardware: rev_10 Factory reset... Factory reset done! Performed by 2.7.4 Software version. | |
11-08-2017, 08:50 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Try to do "Reset Security" from Download Mode. Also we will upload V20D firmware into the Support Area, when firmware will be available, try to write this firmware. |
11-08-2017, 09:11 | #7 (permalink) | |
ok I try to Reset Security on Download mode but After note change Normal Mode The i'll Try to Write V20d Firmware After i'll Replay . Thank You Sir | |
11-08-2017, 12:52 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Unfortunately, we have no other solution for this issue. Try also to write firmware using original LG tools (LGUP or Mobile Support Tool). |
