FRP failed [Solved] Work ID: 0000000000A12568 Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: Q720QM Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q720CS IMEI: 355691-10-******* Android version: 9 Battery level: 58% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ720CSAT-01-V10n-310-150-FEB-04-2020-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: VS02S191216000853 IMEI: 355691-10-*******-3 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: roberto1 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "Q720QM_355691********_23-02-2021_21-50-02.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Failed! Performed by 3.1.0 Software version. |
Hello. We added You one more attempt. Please, try to repeat Reset FRP operation again and post here result. |
done I did it with the FRP tool and it went through , thanks for the refund |
