02-18-2023, 23:05 | #1 (permalink) |
Insane Poster Join Date: Jun 2018 Location: COTE D'IVOIRE
Member: 2843202 Status: Offline Thanks Meter: 15 | Frp lg q520n android 11 fail [Solved] Work ID: 0000000001D5DD8C Checking data...OK Platform: LG MTK Selected port: COM43 Selected baudrate: 0 Selected model: Q520N Connecting to phone... Phone found at port COM43 Mode: Emergency Initializing flash...OK Model ID: LM-Q520N Platform: mt6765 Code name: meh35lm Android version: 11 SW version: LMQ520NAT-00-V20h-KT-KR-JAN-20-2022+0 LAF Version: 1.1 Product ID: 09SGDD24Q3TZ06DW8 IMEI: 352135-74-0383XXXX Target operator: LAO Hardware: rev_11 Battery level: 34% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 352135-74-03838XXX Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is not present. Checking Activations...OK Username: XXXXXX Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 50 credits. To perform "Reset FRP" operation you need to have 20 credits. Please, connect powered OFF phone with USB cable. Found port COM43 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM41 Failed! Performed by 3.2.1 Software version. |
02-19-2023, 13:08 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. Your phone's firmware version Quote:
You can reflash to V10 firmware version then perform need operation. | |
02-19-2023, 18:34 | #3 (permalink) |
Member: 2843202 Status: Offline Thanks Meter: 15 | thank you sir it worked with downgrade to android 10 and do frp with octoplus |
The Following User Says Thank You to beibrofulgence For This Useful Post: |
