03-27-2016, 21:18 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231942 Status: Offline Thanks Meter: 19 | h960 imei how to write ? -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM5 Selected model: H960TR Reading info... Model ID: LG-H960TR IMEI: 355852-07-004894-2 Android version: 6.0 Battery level: 100% Mode: Normal Performed by 2.2.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: H960TR Reading info... Model ID: LG-H960TR IMEI: 355852-07-004894-2 Android version: 6.0 Battery level: 100% Mode: Normal Fixing IMEI... New IMEI: 356826-02-263787-8 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items...Canceled! Backup saved to "H960TR_355852070048942_27-03-2016_23-08-49.qcn" Performed by 2.2.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: H960TR Reading info... Model ID: LG-H960TR IMEI: 355852-07-004894-2 Android version: 6.0 Battery level: 100% Mode: Normal Fixing IMEI... New IMEI: 356826-02-263787-8 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items...Canceled! Backup saved to "H960TR_355852070048942_27-03-2016_23-09-56.qcn" Performed by 2.2.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: H960TR Reading info... Model ID: LG-H960TR IMEI: 355852-07-004894-2 Android version: 6.0 Battery level: 100% Mode: Normal Fixing IMEI... New IMEI: 356826-02-263787-8 Skip Read/Write QCN Do you want to create security backup? Writing security area...Failed! Performed by 2.2.4 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM6 Selected model: H960TR Reading info... Model ID: LG-H960TR IMEI: 355852-07-004894-2 Android version: 6.0 Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH960TRAT-00-V20b-TUR-XX-FEB-16-2016+0 LAF Version: 1.1 Product ID: YE02S151211002532 IMEI: 355852-07-004894-2 Target operator: GLOBAL Hardware: rev_10 Performed by 2.2.4 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H960TR Reading info... Model ID: LG-H960TR IMEI: 355852-07-004894-2 Android version: 6.0 Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH960TRAT-00-V20b-TUR-XX-FEB-16-2016+0 LAF Version: 1.1 Product ID: YE02S151211002532 IMEI: 355852-07-004894-2 Target operator: GLOBAL Hardware: rev_10 Fixing IMEI... New IMEI: 356826-02-263787-8 Skip Read/Write QCN Do you want to create security backup? Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.2.4 software version. |
03-28-2016, 07:57 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, make sure that You perform these steps: To connect the phone in Normal Mode, do one of the following: Enable "USB Debugging" mode; Type 277634#*# or *#546368#*960# for coresponding Android version 5.x or 6.x, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". Also make sure that You install all drivers according to the Software manual, phone must be connected via USB cable directly to USB port of your PC, don't use USB HUBS. Quote:
03-26-2017, 13:11 | #3 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2699810 Status: Offline Thanks Meter: 0 | i have device LG F600L i have flash file but I made a software with another model H960TR after flash in model H960TR no network i tried repair imei with octopus .. imei ok but no network maybe it need qcn file plz help me |
03-27-2017, 08:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to re-flash the device wit correct firmware file for F600L phone model. Last edited by Octopus box; 03-27-2017 at 08:50. |
