help error update my octopus card [Solved] Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 02028*** Selected card: 0002028B*** Updates count: 27 Updates limit: 36 Activations: - LG - FULL (ver 2.4) - Samsung - FULL (ver 2.4) Creating secure connection... [0000.2]Exception: ''$ [0000]Exception: RichEdit line insertion error Requesting firmware... Writing card firmware... Failed! Error at cmd #4 |
download this setup after install update card Octopus Box Downloads - Software, Drivers, Manual |
my updater is new version done download its same problem update error |
check card driver install card driver |
@haron_d Hello. Please, make screenshot of your device manager with connected box and card, after post here or send us screenshot we will check it. |
i update 2 times but same problem http://i1094.photobucket.com/albums/...rlynteck/g.png now the card update count is zero Quote:
Please, try to do next: (official we haven't support Windows XP, please install Software and connect box to PC with Win 7 / 8 10 versions) remove card from box, clean all contacts, insert back into box and try to update card again, if problem still remain, remove card from box, insert into another card reader, dongle and try to update card, if problem still remain, most likely your card is damaged via third party Software. |
yes i try please refel my updates counts Quote:
http://i1094.photobucket.com/albums/...ynteck/ddd.jpg |
We have added You more update counts, please update your card again. |
thanks i try update thin post the result |
help error update my octopus card [Solved] Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 00039B** Selected card: 0000039B** Updates count: 2 Updates limit: 17 Activations: - LG - FULL (ver 2.4) Creating secure connection... Connection error! Could not create secure connection! http://s9.postimg.org/3rj63z2zz/2016_09_23_220906.jpg |
Please install the latest Software version, then try to update the card again. If problem will remain - check that there is no firewall, antivirus or scanning software enabled that would be contributing to this problem. |
Computer Chance Bat Problem same Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 00039B** Selected card: 0000039B** Updates count: 2 Updates limit: 17 Activations: - LG - FULL (ver 2.4) Creating secure connection... Connection error! Could not create secure connection! |
Please, try to use another internet connection to update your card. |
Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 00039*** Selected card: 0000039*** Updates count: 2 Updates limit: 17 Activations: - LG - FULL (ver 2.4) Creating secure connection... Connection error! Could not create secure connection! |
