02-14-2015, 17:31 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 197391 Status: Offline Thanks Meter: 2 | LG card updater card not valid [Solved] Searching for server... Trying connect to server support.octoplusbox.com:4000... Server is online Server greeting: "Card updates server v.2.2" Testing connection... OK Checking validity... OK Checking your cards... Searching installed cards... Found card with s/n XXXXXXXX The card is not valid card. Found 0 cards. Please, check if the cards are inserted and all software that are working with the cards are closed The serial number the updater sees is missing a 1 at the beginning compared to what is on the box and what the Octopus Samsung software sees. Last edited by Octopus box; 02-15-2015 at 09:35. |
02-14-2015, 17:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1.Disconnect all other boxes and card readers from your PC. 2. Install/re-install this driver. 3. Reboot the PC. 4. Reconnect Octopus Box. 5. Try to update card again. |
