Help flashing p768g problem Hello, im triying to flash p768g but stuck here: Welcome to Octoplus/Octopus Box LG Software version 1.8.3 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768g Opening "LGP768gAT-00-V10a-AMX-XXX-DEC-17-2012+0_AP.oct"... -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768g Opening "LGP768gAT-00-V10a-AMX-XXX-DEC-17-2012+0_AP.oct"...OK Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...OK Sending loader... What should i do? Tried two different computer and same, have 3 phones 3 same situation. Process stuck there |
Hello. What is the state of the phone? Why did You decide to reflash it? |
It restarts constantly have 3 same condition and decide to try flashing |
Try to use different USB ports of PC motherboard. Try to perform "Repair" operation, then try to write firmware again. If after of performing Repair procedure, problem will remain, currently no solution for such devices. Also, this can be HW problem. |
Try repair option Welcome to Octoplus/Octopus Box LG Software version 1.8.3 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768g Please, select firmware file -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: P768g Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) and nothing happenns |
Most likely, your device has HW issues. |
Ok thanks for your time support |
