11-18-2016, 06:24 | #1 (permalink) |
No Life Poster Join Date: May 2015 Age: 40
Member: 2394595 Status: Offline Thanks Meter: 24 | LG D850 unlock error [Solved] Platform: LG Qualcomm Selected port: COM56 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-310438-4 Android version: 5.0.1 Battery level: 34% SW Version: D85021r Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Sending exploit...OK Performed by 2.4.7 Software version. all root method failed and how to switch "Port Check Test" to "Enabled". code not working 277634#*# or *#546368#*850# or 3845*#850#, Last edited by Octopus box; 11-18-2016 at 12:05. |
11-18-2016, 09:33 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, install the latest Software version, then repeat the operation again and post here the result. Last edited by Octopus box; 11-18-2016 at 11:28. |
11-18-2016, 11:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, check which phone model exactly do You have on phone's pcb, then select correct phone model in Software and repeat Unlock operation again. |
11-18-2016, 11:32 | #5 (permalink) |
Member: 2394595 Status: Offline Thanks Meter: 24 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM56 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-310438-4 Android version: 5.0.1 Battery level: 68% SW Version: D85021r Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Aug 17 2015 Firmware released time: 21:07:06 SW Version: MPSS.DI.2.0.1.c1.13-00058-M8974AAAAANPZM-1 IMEI: 014065-00-310438-4 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D850_014065003104384_18-11-2016_15-12-28.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D850_014065003104384_18-11-2016_15-26-34.SEC" Switching to Normal mode... Found model LG-D850 at port COM56 Writing security area...OK Rebooting phone... Found model LG-D850 at port COM56 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.5.0 Software version. |
