07-21-2015, 08:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | P990 repair problem -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Tegra Selected model: P990 Opening "LGP990AT-01-V20s-218-90-MAY-21-2012+0_AP.oct"...OK Please, disconnect cable, reconnect battery, press and hold "Vol+"+"Vol-" and connect Micro USB cable... Initializing device...OK Sending loader...OK Creating Boot Config Table...OK Creating Partition Table...OK Creating Fastboot...OK Creating Master Boot Record...OK Creating System...OK Creating CAC...OK Creating Misc...OK Creating Extended Boot Record 1...OK Creating Linux kernel...OK Creating Extended Boot Record 2...OK Creating Digital Rights Management...OK Creating Extended Boot Record 3...OK Creating Recovery...OK Creating Extended Boot Record 4...OK Creating User data A...OK Creating Extended Boot Record 5...OK Creating User data B...OK Formating Boot Config Table...OK Formating Partition Table...OK Formating Fastboot...OK Formating Master Boot Record...OK Formating System...OK Formating CAC...OK Formating Misc...OK Formating Extended Boot Record 1...OK Formating Linux kernel...OK Formating Extended Boot Record 2...OK Formating Digital Rights Management...OK Formating Extended Boot Record 3...OK Formating Recovery...OK Formating Extended Boot Record 4...OK Formating User data A...OK Formating Extended Boot Record 5...OK Formating User data B...OK Writing Fastboot...OK Writing Linux kernel...OK Writing Recovery...OK Finalizing...Failed! Disconnected. |
07-21-2015, 10:35 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. What is exact state of the phone after "Repair" operation? Have You tried to reflash the phone? To perform "Write Firmware" operation, do the next: 1. Power phone OFF. 2. Remove SD and SIM cards from the phone. 3. Connect phone with P999 cable (with 910kOm resistor) and power it ON. 4. Select "Tegra" connection mode. 5. Select firmware file. 6. Click "Write firmware" button. 7. Follow software instructions (prompts). |
07-22-2015, 08:48 | #3 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
firmware write not connect phone | |
07-22-2015, 14:43 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | What exactly You mean by "not connect phone"? What devices appear in PC Device Manager when You connect the phone directly to PC via P999 cable? What appears on phone's screen? |
07-23-2015, 15:03 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Please try to perform "Repair" operation with different firmwares (try to use V10, V20, V30 firmwares from the Support Area). If problem will remain the same for different firmwares, then, most likely, your device has HW problem. |
