I cant flash LG H631 with H631_V20i_00_1018.oct from support Checking data...OK Platform: LG Qualcomm Selected port: COM44 Selected model: H631 Reading info... Model ID: LG-H631 IMEI: 358387-06-021450-8 Android version: 6.0 Battery level: 88% SW Version: H63120b Mode: Emergency Initializing flash...OK SW version: LGH631AT-01-V20b-310-260-FEB-16-2016-ARB01+0 Android version: 6.0 LAF Version: 1.1 Product ID: CT01S150420006408 IMEI: 358387-06-021450-8 Target operator: TMO Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "H631_V20i_00_1018.oct"...OK Setting options...Failed! Error code: ZXLCALSZXC Performed by 2.6.2 Software version. |
Hello. What is exact state of your phone? Why You have decided to re-flash it? |
Because the phone is blocked and restart after 10s to power on... |
Please check phone's battery, even if Software shows battery level 88%. Also, if your phone automatically restarts and shows the error when You try to write firmware (Setting options...Failed!), this can be HW issue. |
i installed h631 V10e using octoplus and phone is now bricked. can anyone help? its LG-h631 T mobil phone. i installed V10g fine with no problems |
