10-19-2020, 18:49 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Russia
Member: 2381134 Status: Offline Thanks Meter: 142 | IMEI REPAIR Stylo 6 Q730TM [Solved] Platform: LG MTK Selected port: COM47 Selected baudrate: 921600 Selected model: Q730TM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM46 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-LAO-COM-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: LS03S200713XXXXXXX IMEI: 354527-11-422966-3 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-422966-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_3545271XXXXXXXXXX_19-10-2020_13-18-09.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: 9c1XXXXXX Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 1900 credits. To perform "Repair IMEI" operation you need to have 100 credits. Fixing IMEI... New IMEI A: 356327-11-XXXXXXXXXXXXX Patching security... Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK IMEI successfully fixed! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.5.03 Software version. After this imei did not repair and stayed the same please need assistance. |
10-19-2020, 19:45 | #2 (permalink) |
Member: 2381134 Status: Offline Thanks Meter: 142 | SECOND ATTEMPT Selected USB connection type Work ID: 000000000012DC3F Checking data...OK Platform: LG MTK Selected port: COM47 Selected baudrate: 921600 Selected model: Q730TM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM46 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-LAO-COM-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: LS03S2007XX IMEI: 354527-11-XXXXXXXXXXX Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-XXXXXXXX Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_354527114229663_19-10-2020_14-34-25.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: 9c1d8kt Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 1800 credits. To perform "Repair IMEI" operation you need to have 100 credits. Fixing IMEI... New IMEI A: 356327-11-XXXXXXXXX Patching security... Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK IMEI successfully fixed! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.5.06 Software version. |
10-19-2020, 19:53 | #3 (permalink) |
Member: 2381134 Status: Offline Thanks Meter: 142 | Worked the second time. Please inform me process to get refund as i was deducted twice for the same job. |
The Following 2 Users Say Thank You to rara1212 For This Useful Post: |
