09-24-2020, 22:45 | #1 (permalink) |
Insane Poster Join Date: Jun 2014
Member: 2207819 Status: Offline Thanks Meter: 24 | Issues while removing FRP [Answered] Welcome to Octoplus/Octopus Box LG Software version 3.0.4 Card S/N : -------------------------------------------------------------------------------- Connecting to server ...OK Username: Cesarbro1 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM74 Selected model: Q710TS Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q710TS IMEI: 35 Android version: 8.1.0 Battery level: 98% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ710TSAT-01-V11s-310-260-FEB-24-2020-ARB00 +0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS93S190325002159 IMEI: 3559 Target operator: LAO Hardware: rev_11 Reading partitions...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Cesarbro1 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "Q710TS_355931094044010_24-09-2020_14- 38-33.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...Failed! Performed by 3.0.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM74 Selected model: Q710TS Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-Q710TS IMEI: 355 Android version: 8.1.0 Battery level: 98% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMQ710TSAT-01-V11s-310-260-FEB-24-2020-ARB00 +0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS93S190325002159 IMEI: 355 Target operator: LAO Hardware: rev_11 Reading partitions...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Cesarbro1 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Too low balance to provide the security operation! Your balance: 0 credits. To perform "Reset FRP" operation you need to have 100 credits. Performed by 3.0.4 Software version. |
