08-18-2020, 17:26 | #1 (permalink) |
Insane Poster Join Date: Apr 2014 Location: yem
Member: 2172436 Status: Offline Sonork: lololo Thanks Meter: 2 | k500um unlock Failed ... help [Answered] Card S/N : 0100026E76 -------------------------------------------------------------------------------- Connecting to server ...OK Username: baq50 Authorizing...OK Checking balance...OK Your balance: 104 credits. -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM28 Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable.Canceled! Performed by 3.0.2 Software version. -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM28 Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable.Canceled! Performed by 3.0.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM28 Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM13 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Incompatible model ID! Platform: mt6765 Android version: 9 SW version: LMK500UM3AT-00-V10d-310-120-MAY-11-2020- ARB00+0 LAF Version: 1.1 Product ID: VP01S200410007356 IMEI: 352488-11-070012-8 Target operator: LAO Hardware: rev_10 Battery level: 56% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 352488-11-070012-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: baq50 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 104 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area...OK Removing write protection...OK Reconnecting phone... Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. Phone found at port COM13 Mode: Emergency Initializing flash...Failed! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2 Software version. |
08-19-2020, 08:33 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please download and install latest test software version 3.0.2.04 from the Support Area (LG/TEST SOFTWARE/), put the phone into download mode then repeat the operation once again. We added you one more attempt. Quote:
