11-25-2020, 13:03 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: egypt Age: 45
Member: 155242 Status: Online Thanks Meter: 136 | K510EMW unlocked done Selected USB connection type Work ID: 000000000029445A Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 921600 Selected model: K510EMW Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM6 Mode: Emergency Initializing flash...OK Model ID: LM-K510EMW Platform: mt6765 Android version: 9 SW version: LMK510EMWAT-64-V10f-EEA-XX-SEP-10-2020+0 LAF Version: 1.1 Product ID: WI25S200511000763 IMEI: 353266-11-xxxxxx-x Target operator: LAO Hardware: rev_10 Battery level: 32% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353266-11-xxxxxx-x IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K510EMW_353266111xxxxx_24-11-2020_23- 43-23.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: QsXSP37cAo Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.7 Software version. |
The Following User Says Thank You to adriano II For This Useful Post: |
