01-10-2017, 12:48 | #16 (permalink) |
No Life Poster Join Date: Dec 2013
Member: 2085670 Status: Offline Thanks Meter: 35 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM90 Selected model: K520DY Reading info... Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10c-AME-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160415006347 IMEI: 357952-07-037725-5 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10d_00_1123.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.5.3 Software version. |
01-10-2017, 13:01 | #17 (permalink) |
Member: 2085670 Status: Offline Thanks Meter: 35 | Welcome to Octoplus/Octopus Box LG Software version 2.5.5.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM90 Selected model: K520DY Reading info... Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10c-AME-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160415006347 IMEI: 357952-07-037725-5 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10d_00_1123.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.5.3 Software version. plz gide us how can we rmoved FRP lock and now my set going on (FIRMWARE UPDATE MOAD) not going normail moad |
01-10-2017, 14:10 | #18 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. You are trying to downgrade firmware. We have uploaded firmware version V10c into the Support Area, please try to re-flash then repeat Reset FRP operation again. Last edited by Octopus box; 01-11-2017 at 14:47. |
01-11-2017, 09:45 | #19 (permalink) | |
Member: 2085670 Status: Offline Thanks Meter: 35 | Quote:
Welcome to Octoplus/Octopus Box LG Software version 2.5.6.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM90 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-037725-5 Android version: 6.0.1 Battery level: 52% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10c-AME-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160415006347 IMEI: 357952-07-037725-5 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10c_00_0517.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.6.1 Software version. see this Sir not flash seam error | |
01-11-2017, 13:13 | #21 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have prepared test Software version and uploaded converted firmware v10d version for your device (if You already have it, then re-download it again from the Support Area). Install test Software version ("LG/TEST SOFTWARE/" folder on the Support Area) and try to re-flash your phone again with V10d version firmware. Last edited by Octopus box; 01-11-2017 at 14:02. |
01-11-2017, 14:40 | #22 (permalink) |
Freak Poster Join Date: May 2006
Member: 272970 Status: Offline Sonork: 100.1604883 Thanks Meter: 39 | lg k520dy after reset frp stock on download mode help octopus team after reset frp stock on download mode.i flashed but always failed. Welcome to Octoplus/Octopus Box LG Software version 2.5.6 Converting files... Unpacking "C:\LG Flash Tool 2014\K520DY10d_00_1123_2.kdz"...OK Opening "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_1123_ 2\K52010x_00.dz"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "sbl1_1024.bin"...OK Unpacking "tz_2048.bin"...OK Unpacking "hyp_3072.bin"...OK Unpacking "rpm_4096.bin"...OK Unpacking "aboot_5120.bin"...OK Unpacking "sbl1bak_12288.bin"...OK Unpacking "tzbak_13312.bin"...OK Unpacking "hypbak_14336.bin"...OK Unpacking "rpmbak_15360.bin"...OK Unpacking "abootbak_16384.bin"...OK Unpacking "persist_53248.bin"...OK Unpacking "laf_93184.bin"...OK Unpacking "boot_142336.bin"...OK Unpacking "recovery_191488.bin"...OK Unpacking "recoverybak_240640.bin"...OK Unpacking "sec_295936.bin"...OK Unpacking "rct_299008.bin"...OK Unpacking "factory_316416.bin"...OK Unpacking "modem_513024.bin"...OK Unpacking "cust_688128.bin"...OK Unpacking "system_892928.bin"...OK Unpacking "system_1156616.bin"...OK Unpacking "system_1160632.bin"...OK Unpacking "system_1421232.bin"...OK Unpacking "system_1680904.bin"...OK Unpacking "system_1684920.bin"...OK Unpacking "system_1945520.bin"...OK Unpacking "system_2205192.bin"...OK Unpacking "system_2209208.bin"...OK Unpacking "system_2469808.bin"...OK Unpacking "system_2729480.bin"...OK Unpacking "system_2733496.bin"...OK Unpacking "system_2994096.bin"...OK Unpacking "system_3253768.bin"...OK Unpacking "system_3257784.bin"...OK Unpacking "system_3518384.bin"...OK Unpacking "system_3780528.bin"...OK Unpacking "system_4042672.bin"...OK Unpacking "system_4304816.bin"...OK Unpacking "system_4566960.bin"...OK Unpacking "system_4829104.bin"...OK Unpacking "system_5091248.bin"...OK Unpacking "system_5353392.bin"...OK Unpacking "system_5615536.bin"...OK Unpacking "system_5877680.bin"...OK Unpacking "system_6139824.bin"...OK Unpacking "system_6401968.bin"...OK Unpacking "system_6660096.bin"...OK Unpacking "system_6922240.bin"...OK Unpacking "system_6925304.bin"...OK Unpacking "OP_7651328.bin"...OK Unpacking "OP_7913472.bin"...OK Unpacking "OP_8175616.bin"...OK Unpacking "OP_8178832.bin"...OK Unpacking "BackupGPT_30534656.bin"...OK Unpacking done. Processing files... Identifying sub-files...OK Creating destination file...OK Deleting temporary files... Deleting directory "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_ 00_1123_2\"... Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\aboot"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\abootbak"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\BackupGPT"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\boot"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\cust"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\factory"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\hyp"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\hypbak"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\K52010x_00.dz"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\laf"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\modem"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\OP"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\parts.bin"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\persist"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\PrimaryGPT"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\rct"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\recovery"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\recoverybak"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\rpm"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\rpmbak"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\sbl1"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\sbl1bak"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\sec"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\system"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\tz"...OK Deleting file "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_ 1123_2\tzbak"...OK Directory "C:\Users\JADEN-~1\AppData\Local\Temp\K520DY10d_00_1123 _2\" succesfully deleted! Firmware convert done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM138 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-011351-0 Android version: 6.0.1 Battery level: 100% SW Version: K52010d Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10d-ESA-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160416004852 IMEI: 357952-07-011351-0 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10d_00_1123_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...Failed! Performed by 2.5.6 Software version. |
01-11-2017, 14:48 | #23 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @margallo We have prepared test Software version and uploaded converted firmware v10d version for your device (if You already have it, then re-download it again from the Support Area). Install test Software version ("LG/TEST SOFTWARE/" folder on the Support Area) and try to re-flash your phone again with V10d version firmware. |
01-12-2017, 00:19 | #25 (permalink) |
Member: 272970 Status: Offline Sonork: 100.1604883 Thanks Meter: 39 | flashing done.but failed on frp reset Welcome to Octoplus/Octopus Box LG Software version 2.5.6.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM138 Selected model: K520DY Reading info... Model ID: LG-K520DY IMEI: 357952-07-011351-0 Android version: 6.0.1 Battery level: 100% SW Version: K52010d Mode: Emergency Initializing flash...OK SW version: LGK520DYAT-00-V10d-ESA-XX-NOV-23-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160416004852 IMEI: 357952-07-011351-0 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K520DY10d_00_1220.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing sbl1...OK Writing tz...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing sec...OK Writing factory...OK Writing modem...OK Writing cust...OK Writing system...OK Writing OP...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.6.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM138 Selected model: K520DY Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-K520DY IMEI: 357952-07-011351-0 Android version: 6.0.1 Battery level: 100% SW Version: K52010f Mode: Normal Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Step 1... LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware.Failed! Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.5.6.3 Software version. |
01-12-2017, 08:51 | #27 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately, Rest FRP operation isn't supported on new firmware version, we are working on solution stay tuned for future updates. |
