01-10-2017, 17:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | D855 after updte wifi and memory card not working |
01-11-2017, 09:32 | #3 (permalink) |
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | Welcome to Octoplus/Octopus Box LG Software version 2.5.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM34 Selected model: D855 Reading info... Model ID: LG-D855V IMEI: 355673-06-746477-1 Android version: 6.0 Battery level: 16% SW Version: D85530o Mode: Emergency Initializing flash...OK SW version: LGD855VAT-00-V30o-GLOBAL-COM-SEP-27-2016-32G+0 Android version: 6.0 LAF Version: 1.1 Product ID: PT02S141003006567 IMEI: 355673-06-746477-1 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "d85530e_00_0927.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! |
01-11-2017, 09:42 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As we see from your Software log, You have downgraded phone's firmware from version V30o to V30e: Quote:
01-11-2017, 14:26 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As we can see from the Software log, your phone model is D855V, but You have flashed the phone with firmware which are declared for another phone model D855. Please, select correct firmware file for your device, then repeat Write Firmware operation, then check phone's work. |
01-11-2017, 15:54 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone wit V20 version from the Support Area, after post here full Software log and check phone's work. |
01-12-2017, 06:05 | #12 (permalink) |
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | Welcome to Octoplus/Octopus Box LG Software version 2.5.5 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D855 Reading info... Model ID: LG-D855V IMEI: 355673-06-746477-1 Android version: 6.0 Battery level: 59% SW Version: D85530o Mode: Emergency Initializing flash...OK SW version: LGD855VAT-00-V30o-GLOBAL-COM-SEP-27-2016-32G+0 Android version: 6.0 LAF Version: 1.1 Product ID: PT02S141003006567 IMEI: 355673-06-746477-1 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "d855_v20i_00_32gb.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Still same problem |
