LG-D855 no 3g after repair imei after i did repair imei there is a 3g for about an hour and then it gone and no service.. if i switch to 2g (gsm) network is ok but only on gsm please help me i also tried to make reset security and the IMEI become 0 it works fine for about a day and then no service again |
Hello. Post here (or send us to PM, if You can't post here) full Software log with all of your actions. All logs are saved here: "c:\Program Files\Octoplus\Octoplus_LG\LOG\". |
i send it to your email |
The problem is You have skiped Read/Write QCN during of Repair IMEI procedure. Now You need to find or read out QCN from the same device with working (active) 3G network and write this QCN into your phone. Also, try to write QCN, that we have sent You to PM, then insert SIM card, wait 5-7 minutes and check, whether 3G is active. |
already try that i have opened a new D855 and did a READ qcn AND read security and then write to the problematic D855 it worked for about a hour and got back to the problem with 3G network.. |
Try to re-flash the phone; try to read out QCN from another one D855 and write it; try to make Factory/Hard reset. |
did that already flashed a stock firmware with lg flash tool readed QCN from a new unopened phone write the new Qcn to the bad phone did factory reset and it is still the same |
fix Solution i have been Finding to work is either use the older version under 1.69 to repair and have no problem or Dont use qcn at all on the lg , use just nvm backups only way to get lte again or 4g, you may have to write good nvm go back to old version and do it all over, but its what i found works consistently |
And the the 3g/4g will not dissapear after a couple of days? |
