05-23-2011, 18:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Where the cash @... Age: 38
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | LG P506GO dead after flash Platform: LG Qualcomm Selected port: COM67 Selected model: P506GO Phone model: P506GO Mode: Emergency Opening "LGP506GOAT-01-V11e-310-410-MAR-05-2011+0.oct"...OK Writing Firmware... -------------------------------------------------------------------------------- Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. -------------------------------------------------------------------------------- Checking partition...OK Writing AMSS...OK Writing Boot image...OK Writing System...OK Writing Recovery image...OK Writing Splash image...OK Finalizing...OK Writing Firmware done! To finish the operation please power on phone and wait 3 minutes Please help me... It's urgent ... Thanks... BR, ERIC |
05-24-2011, 08:06 | #4 (permalink) | |
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | Quote:
The problem is the phone doesn't even get into emergency mode... I think boot is dead... Is there any tool which can repair this phone? It's urgent guys need help... BR, ERIC | |
05-24-2011, 09:40 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. Please, check battery voltage level. It should be > than 4V. To enter emergency mode, disconnect cable, reconnect battery, press and hold "Back"+"Vol+"+"Power ON" buttons and connect cable. |
05-25-2011, 09:17 | #6 (permalink) | |
BR, ERIC | |
05-27-2011, 04:46 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Heelo. Yes, You can resurrect P506GO boots via Medusa Box. The list of supported devices You can find here: Medusa Box Features: read/write boot, flash and repair LG, Samsung, Huawei and other brands cell phones. |
06-06-2013, 11:48 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | What "the same issue" do You mean? Please explain the problem in more details, step by step. Also post here full software log with all of your actions. |
01-11-2014, 09:53 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. No need to write special firmware for unlock. Direct unlock is supported: http://forum.gsmhosting.com/vbb/7858231-post97.html. Now, after the error occured during writing firmware, You should do the next: 1. Install the latest Software version. 2. Put the phone into Emergency Mode (disconnect the cable, re-connect the battery, press and hold "Vol +" + "Back" + "Power on" keys and connect the cable). 3. Select normal (not special) firmware from the Support Area. 4. Select (check) "Write boot loaders" option. 5. Press "Write Firmware" button. If an error will occurs during writing firmware, You mandatory should disconnect the cable, reconnect the battery, manually put phone into Emergency Mode and repeat the procedure of writing firmware. It is very important to put the phone into Emergency Mode manually! Then You can make "Unlock". To perform "Unlock" operation, do the next: 1. Put the phone into Emergency Mode manually (disconnect the cable, re-connect the battery, press and hold "Vol +" + "Back" + "Power on" keys and connect the cable). 2. Press "Unlock" button. Please, always use the latest Software version and attentively read Software manual ("Help" button in Software) before to perform any operation. |
10-13-2014, 18:43 | #14 (permalink) |
Product Supporter Join Date: Nov 2006 Location: Ecuador, Shenzhen, Guangzhou Age: 55
Member: 394446 Status: Offline Sonork: 100.1579789 Thanks Meter: 74 | Problems with P506go, I have done all process on this unit! Original problem was it was taking long to open apps! I flashed the first time without boot and although all flashed ok it stayed on LG logo! Then put on emergency mode manual and flashed again with boot loader same result stuck on LG logo. Then put on EM and tried fixing security but failed and left phone with black screen so i flashed again in EM and finished flash but stuck on LG logo again. I am using 1.7.1 version software and flashed with both P506 y P506go. Please help Last edited by otto68; 10-13-2014 at 18:52. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
