05-14-2015, 13:37 | #1 (permalink) | |
Freak Poster Join Date: Jun 2010 Location: GSM Bunker
Member: 1330441 Status: Offline Thanks Meter: 95 | Error writing firmware E465G Quote:
05-14-2015, 13:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the problem with your device exactly? What is the state of the phone? Why do You want to re-flash the phone? |
05-14-2015, 16:11 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | In general, such error arise, when phone has HW issues. Also, such problem can arise, when phone has user (phone) code, currently no solution for such case. Connect the phone directly to PC motherboard USB port (don't use any USB hubs, this is important) and try to write firmware again. Try to find and write another firmware. If the problem is the same - check HW. |
06-03-2015, 03:11 | #5 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | im getting this error... any idea how to repair it??? -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM256 Selected baudrate: 921600 Selected model: E465G Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. CPU name: MT6575 CPU revision: 8A00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Failed to read loader version! |
06-03-2015, 09:02 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You should connect the phone directly to PC motherboard USB port (don't use any USB hubs, this is important). Try to use different USB ports of PC motherboard for connection. If problem will be the same on different USB ports: Quote:
