09-30-2015, 17:36 | #1 (permalink) |
Freak Poster Join Date: May 2013
Member: 1939108 Status: Offline Thanks Meter: 44 | D850 error code:ZXLCALSZXD -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM330 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-424144-1 Android version: 5.0.1 Battery level: 46% Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Jun 4 2015 Firmware released time: 08:36:12 SW Version: MPSS.DI.2.0.1.c1.13-00058-M8974AAAAANPZM-1 IMEI: 014065-00-424144-1 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D850_014065004241441_30-09-2015_12-15-21.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D850_014065004241441_30-09-2015_12-26-25.SEC" Writing security area...OK Switching to Normal mode... Found model LG-D850 at port COM330 Send SPC...OK Writing QCN... Writing NV_Numbered Items...Failed! Error code: ZXLCALSZXD |
09-30-2015, 18:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please repeat "Unlock" operation with enabled "Skip Read/Write QCN during Unlock operation" option. Post here result and full Software log of the operation. |
10-03-2015, 13:28 | #3 (permalink) |
No Life Poster Join Date: May 2002 Location: TX Age: 49
Member: 12427 Status: Offline Thanks Meter: 78 | Also getting the same error when repairing imei Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 014065-00-67----- Android version: 4.4.2 Battery level: 100% Mode: Normal Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014065-00-67----- SPC: 000000 Fixing IMEI... New IMEI: 014065-00-67----- Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D850_0140650067-----_03-10-2015_07-17-44.SEC" Writing security area...Failed! Error code: ZXLCALSZXD |
10-03-2015, 14:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please install latest Software version and repeat "Unlock" operation with enabled "Skip Read/Write QCN during Unlock operation" option. Post here result and full Software log of the operation. |
10-03-2015, 14:45 | #5 (permalink) |
Member: 12427 Status: Offline Thanks Meter: 78 | Tried with 2.0.6 Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D850 Reading info... Model ID: LG-D850 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 100% Mode: Normal Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 SPC: 000000 Fixing IMEI... New IMEI: 014065-00-67----- Skip Read/Write QCN Switching to Download mode...OK Initializing flash...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually Power phone OFF, press and hold "Vol+" button and connect the cable 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D850_000000000000000_03-10-2015_08-36-57.SEC" Writing security area...OK Switching to Normal mode... Found model LG-D850 at port COM41 Error code: Z1AL3CAS2Q |
10-03-2015, 15:04 | #6 (permalink) |
Member: 12427 Status: Offline Thanks Meter: 78 | Tried again keep fail when do manual download mode. I then tried again but plug into box USB port then its work. Skip Read/Write QCN Switching to Download mode...OK Initializing flash...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually Power phone OFF, press and hold "Vol+" button and connect the cable 3. Connect cable and press "Ok" button. another time using USB on box and now its work |
10-03-2015, 15:16 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please check your PM, we have sent You a test Software version. Repeat the operation with test Software and post here the result. |
