LG GR500 unlocking failed need help [Solved] Welcome to Octoplus/Octopus Box LG Software version 1.9.8 -------------------------------------------------------------------------------- Platform: LG SEMC Selected port: COM181 Selected baudrate: 921600 Selected model: GR500 Use Testpoint/Jumper: No -------------------------------------------------------------------------------- For correct working the battery must be fully charged! Please, reconnect battery, press and hold camera button and connect USB cable. If phone not connected, connect (solder) jumper according to picture ("Show testpoint" button). Starting... Phone found! Chip ID: 0xD9000401FFFFFFFF Chipset: DB3200 BootROM mode detected Sending ACC preloader...OK Sending APP preloader...OK CID: 54 IMEI: 011793-00-622595-4 Color: Red Sending ACC production loader... Answer timed out Error of sending header Disconnected. -------------------------------------------------------------------------------- Platform: LG SEMC Selected port: COM181 Selected baudrate: 921600 Selected model: GR500 Use Testpoint/Jumper: No -------------------------------------------------------------------------------- For correct working the battery must be fully charged! Please, reconnect battery, press and hold camera button and connect USB cable. If phone not connected, connect (solder) jumper according to picture ("Show testpoint" button). Starting... Phone found! Chip ID: 0xD9000401FFFFFFFF Chipset: DB3200 Answer timed out Sending ACC preloader... Answer timed out No ACK Disconnected. -------------------------------------------------------------------------------- Platform: LG SEMC Selected port: COM181 Selected baudrate: 921600 Selected model: GR500 Use Testpoint/Jumper: No -------------------------------------------------------------------------------- For correct working the battery must be fully charged! Please, reconnect battery, press and hold camera button and connect USB cable. If phone not connected, connect (solder) jumper according to picture ("Show testpoint" button). Starting... Phone found! Chip ID: 0xD9000401FFFFFFFF Chipset: DB3200 BootROM mode detected Sending ACC preloader...OK Sending APP preloader...OK CID: 54 IMEI: 011793-00-622595-4 Answer timed out No ACK Error of reading OTP! Sending ACC production loader... Answer timed out No ACK Error of sending header Disconnected. |
Hello. Please install latest Software version and repeat "Unlock" operation. Post here result and full Software log of the operation. |
LG GR500 unlock Done :) press volume up and inset usb cable then unlock ok Platform: LG SEMC Selected port: COM181 Selected baudrate: 921600 Selected model: GR500 Use Testpoint/Jumper: No -------------------------------------------------------------------------------- For correct working the battery must be fully charged! Please, reconnect battery, press and hold camera button and connect USB cable. If phone not connected, connect (solder) jumper according to picture ("Show testpoint" button). Starting... Phone found! Chip ID: 0xD9000401FFFFFFFF Chipset: DB3200 BootROM mode detected Sending ACC preloader...OK Sending APP preloader...OK CID: 54 IMEI: 011793-00-622595-4 Color: Red Sending ACC production loader...OK Sending APP production loader...OK Unlocking...OK :) Phone successfully unlocked! Disconnected. |
