LG-H440 IMEI Repair Done -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: H440 Reading info... Model ID: LG-H440 IMEI: 359180-06-014864-7 Android version: 5.0.1 Battery level: 36% SW Version: H44010d Mode: Normal Firmware compiled date: Mar 31 2015 Firmware compiled time: 01:00:00 Firmware released date: Oct 14 2015 Firmware released time: 20:13:20 SW Version: MPSS.DPM.2.0.c11-00018-M8936FAAAANUZM-1 IMEI: 359180-06-014864-7 SPC: 000000 Fixing IMEI... New IMEI: 358789-89-778990-1 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H440_359180060148647_29-08-2018_11-39-47.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "H440_359180060148647_29-08-2018_11-47-45.SEC" Switching to Normal mode... Found model EAAAANWZ at port COM48 Writing security area...OK Rebooting phone... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM275 Selected model: H440 Reading info... Model ID: LG-H440 IMEI: 000000-00-000000-0 Android version: 5.0.1 Battery level: 39% SW Version: H44010d Trying to enable Diagnostics ports... Found model EAAAANWZ at port COM275 Fixing IMEI... New IMEI A: 358789-89-778990-1 Finalizing...OK IMEI successfully fixed! Rebooting phone... Performed by 2.8.5 Software version. |
