07-25-2021, 00:31 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | LG-H932 Unlock question [Solved] -------------------------------------------------------------------------------- Work ID: 00000000014EAD4B Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H932 Reading info... Model ID: LG-H932 IMEI: 358165-08-16xxxx-9 Android version: 8.0.0 Battery level: 100% Trying to enable Diagnostics ports... Found model LGH932AT: ÿh at port COM6 Reading info... Model ID: LG-H932 IMEI: 358165-08-16xxxx-9 Android version: 8.0.0 Battery level: 100% Mode: Normal Firmware compiled date: Mar 14 2018 Firmware compiled time: 23:00:00 Firmware released date: Apr 16 2018 Firmware released time: 17:40:03 SW Version: MPSS.AT.2.5.c1.2-00034-8998_GEN_PACK-1.138248.1.140963.1 IMEI: 358165-08-169241-9 SPC: 000000 Unlock operation for H932 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8998 SW version: LGH932AT-01-V20h-310-260-APR-16-2018-64G-ARB00+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: SM06S180316001658 IMEI: 358165-08-16xxxx-9 Target operator: TMO Hardware: rev_10 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Failed! Rebooting phone... Performed by 3.1.4 Software version. |
07-26-2021, 06:27 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,139 | Hello. Try to perform Factory Reset operation and then repeat Unlock operation one more time. Post here results. We will check it. Last edited by Octopus support; 07-26-2021 at 07:36. |
07-26-2021, 20:25 | #7 (permalink) | |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Quote:
Same error: -------------------------------------------------------------------------------- Work ID: 0000000001507180 Checking data...OK Platform: LG Qualcomm Selected port: COM6 Selected model: H932 Reading info... Model ID: LG-H932 IMEI: 358165-08-16xxxx-9 Android version: 8.0.0 Battery level: 99% Mode: Normal Firmware compiled date: Oct 05 2018 Firmware compiled time: 00:00:00 Firmware released date: Mar 6 2019 Firmware released time: 15:27:21 SW Version: MPSS.AT.2.5.c1.2-00046-8998_GEN_PACK-1.170365.1.171938.1 IMEI: 358165-08-16xxxx-9 SPC: 000000 Unlock operation for H932 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: dombronx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8998 SW version: LGH932AT-01-V20s-310-260-MAR-06-2019-64G-ARB00+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: SM06S180316001658 IMEI: 358165-08-16xxxx-9 Target operator: TMO Hardware: rev_10 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Failed! Rebooting phone... Performed by 3.1.4 Software version. | |
07-26-2021, 22:09 | #8 (permalink) |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Tried this and it worked by this way. Phone unlocked now. 1. Connect SD card via SD card reader to PC. 2. Put phone into Download mode manually. 3. Repeat Unlock operation. |
