LG H870 frp remove not done help [Answered] |
Hi. As You can see from your Software log, there is the latest firmware version in your device: Quote:
next update tnx in advance |
LG-H870 Reset FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.7.8.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM46 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Could not detect mode! Performed by 2.7.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM46 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Could not detect mode! Performed by 2.7.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM369 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Mode: Emergency Initializing flash...OK SW version: LGH870AT-00-V10a-724-06-NOV-08-2017+5 Android version: 7.0 LAF Version: 1.1 Product ID: SM06S170407001351 IMEI: 356144-08-107998-6 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 0F0F0F0F. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.7.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM369 Selected model: H870 Reading info... Model ID: LG-H870 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 23% SW Version: H87010a Mode: Emergency Initializing flash...OK SW version: LGH870AT-00-V10a-724-06-NOV-08-2017+5 Android version: 7.0 LAF Version: 1.1 Product ID: SM06S170407001351 IMEI: 356144-08-107998-6 Target operator: GLOBAL Hardware: rev_10 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "H87010l_00_OPEN_EU_OP_0622.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing laf...OK Writing lafbak...OK Writing factory...OK Writing persist...OK Writing system...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl...OK Writing xblbak...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl2...OK Writing xbl2bak...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing tz...OK Writing tzbak...OK Writing aboot...OK Writing abootbak...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing rpm...OK Writing rpmbak...OK Writing hyp...OK Writing hypbak...OK Writing pmic...OK Writing pmicbak...OK Writing devcfg...OK Writing devcfgbak...OK Writing modem...OK Writing sec...OK Writing keymaster...OK Writing keymasterbak...OK Writing cmnlib...OK Writing cmnlibbak...OK Writing cmnlib64...OK Writing cmnlib64bak...OK Writing apdp...OK Writing msadp...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing OP_T...OK Finalizing...OK Writing firmware done! Performed by 2.7.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM369 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870 IMEI: 356144-08-107998-6 Android version: 7.0 Battery level: 21% SW Version: H87010l Mode: Emergency Initializing flash...OK SW version: LGH870AT-00-V10l-724-06-JUN-22-2017+0 Android version: 7.0 LAF Version: 1.1 Product ID: SM06S170407001351 IMEI: 356144-08-107998-6 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.7.8.4 Software version. |
