Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 03-03-2018, 07:46   #1 (permalink)
Member: 2807070
Sonork: 550000
Thanks Meter: 36
LG H870 frp remove not done help [Answered]
Old 03-03-2018, 09:35   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,246
Hi.
As You can see from your Software log, there is the latest firmware version in your device:
SW version: LGH870AT-00-V11j-ZAF-XX-JAN-25-2018+0
Reset FRP operation is currently not supported for your phone's firmware.
In latest firmwares (released in NOV 2017 and latest) possibility to reset FRP by supported methods was closed (fixed). Unfortunately, no solution at the moment. We work on solution and we will release it as soon as the solution will be ready.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 03-05-2018, 12:56   #3 (permalink)
Member: 2807070
Sonork: 550000
Thanks Meter: 36
Originally Posted by Octopus box View Post
Hi.
OK Octopus tnx for your feedback and i hope you will be update in
next update tnx in advance
Old 03-09-2018, 20:27   #4 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
Thumbs up LG-H870 Reset FRP successfully done
Welcome to Octoplus/Octopus Box LG Software version 2.7.8.4
Checking data...OK
Platform: LG Qualcomm
Selected port: COM46
Selected model: H870
Please, put the phone into download mode manually (Power phone OFF,
press and hold "Vol+" button and connect the cable).
Reading info...
Could not detect mode!
Performed by 2.7.8.4 Software version.
Checking data...OK
Reading info...
Checking data...OK
Selected port: COM369
Reading info...
Mode: Emergency
Initializing flash...OK
SW version: LGH870AT-00-V10a-724-06-NOV-08-2017+5
Android version: 7.0
LAF Version: 1.1
Product ID: SM06S170407001351
IMEI: 356144-08-107998-6
Target operator: GLOBAL
Hardware: rev_10
Reading partitions...OK
Resetting FRP Lock...Failed!
LAF Error: 0F0F0F0F.
Checking data...OK
Reading info...
Model ID: LG-H870
IMEI: 000000-00-000000-0
Battery level: 23%
SW Version: H87010a
Mode: Emergency
LAF Version: 1.1
Hardware: rev_10
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Opening "H87010l_00_OPEN_EU_OP_0622.oct"...OK
Setting options...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Sending signature...OK
Writing PrimaryGPT...OK
Writing laf...OK
Writing lafbak...OK
Writing factory...OK
Writing persist...OK
Writing system...OK
Writing BackupGPT...OK
Writing xbl...OK
Writing xblbak...OK
Writing xbl2...OK
Writing xbl2bak...OK
Writing boot...OK
Writing recovery...OK
Writing recoverybak...OK
Writing tz...OK
Writing tzbak...OK
Writing aboot...OK
Writing abootbak...OK
Writing raw_resources...OK
Writing raw_resourcesbak...OK
Writing rpm...OK
Writing rpmbak...OK
Writing hyp...OK
Writing hypbak...OK
Writing pmic...OK
Writing pmicbak...OK
Writing devcfg...OK
Writing devcfgbak...OK
Writing modem...OK
Writing sec...OK
Writing keymaster...OK
Writing keymasterbak...OK
Writing cmnlib...OK
Writing cmnlibbak...OK
Writing cmnlib64...OK
Writing cmnlib64bak...OK
Writing apdp...OK
Writing msadp...OK
Writing OP_T...OK
Finalizing...OK
Writing firmware done!
Checking data...OK
Reading info...
Model ID: LG-H870
Battery level: 21%
SW Version: H87010l
Mode: Emergency
SW version: LGH870AT-00-V10l-724-06-JUN-22-2017+0
LAF Version: 1.1
Hardware: rev_10
Resetting FRP lock successfully completed!
The Following User Says Thank You to Alexandro Monte For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.11957 seconds with 7 queries
