06-02-2020, 10:18 | #1 (permalink) |
Junior Member Join Date: Jul 2007
Member: 551915 Status: Offline Thanks Meter: 0 | lg k40s X430EMW/420EMW withdrawn credit but still locked [Solved] Card S/N : 0001069B5D -------------------------------------------------------------------------------- Connecting to server ...OK Username: zayet005 Authorizing...OK Checking balance...OK Your balance: 200 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM16 Mode: Emergency Initializing flash...OK Model ID: LM-X420EMW Platform: mt6765 Android version: 9 SW version: LMX420EMWAT-64-V20e-EEA-XX-MAR-06-2020+0 LAF Version: 1.1 Product ID: 975GAD29BL7504MMI IMEI: 353615-10-507497-3 Target operator: LAO Hardware: rev_11 Battery level: 17% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353615-10-507497-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: zayet005 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Removing write protection... Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OKOK Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Reading partitions...OK Erasing part 1...OK Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Restore write protection... Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OKOK Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.01 Software version. -------------------------------------------------------------------------------- ***************** Connecting to server ...OK Username: zayet005 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM16 Mode: Emergency Initializing flash...OK Model ID: LM-X420EMW Platform: mt6765 Android version: 9 SW version: LMX420EMWAT-00-V20m-LAO-SI-MAR-06-2020+0 LAF Version: 1.1 Product ID: 975GAD29BL7504MMI IMEI: 353615-10-507497-3 Target operator: LAO Hardware: rev_11 Battery level: 17% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353615-10-507497-3 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: zayet005 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Removing write protection... Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OKOK Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Reading partitions...OK Erasing part 1...OK Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Restore write protection... Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OKOK Reconnecting phone... Phone found at port COM16 Mode: Emergency Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.01 Software version. |
06-02-2020, 10:47 | #2 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 937607 Status: Offline Thanks Meter: 15 | lg k40s X430EMW withdrawn credit but still locked I did a frp reset on a lg X430EMW which cost me 100 credits but is still locked. I have send the admin a PM and also sent an email with all the logs to [email protected] but still there is no answer. Here is the log 01/06/2020 13:32:33 > Searching for server... 01/06/2020 13:32:33 > Trying to ping server...01/06/2020 13:32:33 > ok 01/06/2020 13:32:33 > Trying connect to server... 01/06/2020 13:32:34 > Searching installed cards... 01/06/2020 13:32:34 > Found card with s/n: 0002XXX 01/06/2020 13:32:34 > Server check... 01/06/2020 13:32:34 > Server Check succesfull! 01/06/2020 13:32:34 > Server Check succesfull! 01/06/2020 13:32:36 > Welcome to Octoplus/Octopus Box LG Software version 3.0.2.01 01/06/2020 13:32:36 > Card S/N : 000002XXX 01/06/2020 13:32:41 > INI FUpdateInfo Done! 01/06/2020 13:32:41 > INI FShowUpdateInfo start 01/06/2020 13:32:41 > INI FShowInfo start 01/06/2020 13:32:41 > INI FShowInfo show News Form 01/06/2020 13:32:45 > -------------------------------------------------------------------------------- 01/06/2020 13:32:45 > Checking data...01/06/2020 13:32:46 > OK 01/06/2020 13:32:46 > Platform: LG MTK 01/06/2020 13:32:46 > Selected port: COM163 01/06/2020 13:32:46 > Selected baudrate: 0 01/06/2020 13:32:46 > Selected model: X430EMW 01/06/2020 13:32:46 > Selected USB connection type 01/06/2020 13:32:47 > Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) 01/06/2020 13:32:47 > or 01/06/2020 13:32:47 > Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. 01/06/2020 13:32:48 > Phone found at port COM163 01/06/2020 13:32:48 > Mode: Emergency 01/06/2020 13:32:48 > Initializing flash...01/06/2020 13:32:49 > OK 01/06/2020 13:32:50 > Model ID: LM-X430EMW 01/06/2020 13:32:50 > Platform: mt6765 01/06/2020 13:32:50 > Android version: 9 01/06/2020 13:32:50 > SW version: LMX430EMWAT-00-V10h-EEA-XX-MAR-09-2020+0 01/06/2020 13:32:50 > LAF Version: 1.1 01/06/2020 13:32:51 > Product ID: 9BFAB621DP9Y007AM 01/06/2020 13:32:51 > IMEI: 358854-10-XXXXXX-X 01/06/2020 13:32:51 > Target operator: LAO 01/06/2020 13:32:51 > Hardware: rev_10 01/06/2020 13:32:51 > Battery level: 100% 01/06/2020 13:32:51 > Reading partitions...01/06/2020 13:32:51 > OK 01/06/2020 13:32:51 > LAF Error: 80000119. 01/06/2020 13:32:52 > Checking security...01/06/2020 13:32:52 > OK 01/06/2020 13:32:52 > Reading is Blocked! 01/06/2020 13:32:52 > -------------------------------------------------------------------------------- 01/06/2020 13:32:52 > IMEI A: 358854-10-XXXXXX-X 01/06/2020 13:32:52 > IMEI B: Bad 01/06/2020 13:32:52 > Bluetooth address: Unknown 01/06/2020 13:32:52 > Wi-Fi MAC address: Unknown 01/06/2020 13:32:52 > -------------------------------------------------------------------------------- 01/06/2020 13:32:52 > Connecting to server...01/06/2020 13:32:52 > OK 01/06/2020 13:32:52 > Octopus smart card is present. 01/06/2020 13:32:52 > Checking smart card...01/06/2020 13:32:59 > OK 01/06/2020 13:32:59 > Username: santosh81 01/06/2020 13:32:59 > Authorizing...01/06/2020 13:33:00 > Failed! 01/06/2020 13:33:00 > Login error: Wrong password! 01/06/2020 13:33:00 > Performed by 3.0.2.01 Software version. 01/06/2020 13:33:00 > Elapsed Time: 0:00:14 01/06/2020 13:33:10 > -------------------------------------------------------------------------------- 01/06/2020 13:33:10 > Checking data...01/06/2020 13:33:12 > OK 01/06/2020 13:33:12 > Platform: LG MTK 01/06/2020 13:33:12 > Selected port: COM163 01/06/2020 13:33:12 > Selected baudrate: 0 01/06/2020 13:33:12 > Selected model: X430EMW 01/06/2020 13:33:12 > Selected USB connection type 01/06/2020 13:33:12 > Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) 01/06/2020 13:33:12 > or 01/06/2020 13:33:12 > Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. 01/06/2020 13:33:13 > Phone found at port COM163 01/06/2020 13:33:13 > Mode: Emergency 01/06/2020 13:33:13 > Initializing flash...01/06/2020 13:33:15 > OK 01/06/2020 13:33:16 > Model ID: LM-X430EMW 01/06/2020 13:33:16 > Platform: mt6765 01/06/2020 13:33:16 > Android version: 9 01/06/2020 13:33:16 > SW version: LMX430EMWAT-00-V10h-EEA-XX-MAR-09-2020+0 01/06/2020 13:33:16 > LAF Version: 1.1 01/06/2020 13:33:16 > Product ID: 9BFAB621DP9Y007AM 01/06/2020 13:33:16 > IMEI: 358854-10-XXXXXX-X 01/06/2020 13:33:16 > Target operator: LAO 01/06/2020 13:33:16 > Hardware: rev_10 01/06/2020 13:33:16 > Battery level: 100% 01/06/2020 13:33:16 > Reading partitions...01/06/2020 13:33:16 > OK 01/06/2020 13:33:16 > LAF Error: 80000119. 01/06/2020 13:33:17 > Checking security...01/06/2020 13:33:17 > OK 01/06/2020 13:33:17 > Reading is Blocked! 01/06/2020 13:33:17 > -------------------------------------------------------------------------------- 01/06/2020 13:33:17 > IMEI A: 358854-10-XXXXXX-X 01/06/2020 13:33:17 > IMEI B: Bad 01/06/2020 13:33:17 > Bluetooth address: Unknown 01/06/2020 13:33:17 > Wi-Fi MAC address: Unknown 01/06/2020 13:33:17 > -------------------------------------------------------------------------------- 01/06/2020 13:33:17 > Connecting to server...01/06/2020 13:33:18 > OK 01/06/2020 13:33:18 > Octopus smart card is present. 01/06/2020 13:33:18 > Checking smart card...01/06/2020 13:33:24 > OK 01/06/2020 13:33:24 > Username: omdipti1 01/06/2020 13:33:24 > Authorizing...01/06/2020 13:33:25 > OK 01/06/2020 13:33:25 > Checking balance...01/06/2020 13:33:26 > OK 01/06/2020 13:33:26 > Checking operation...01/06/2020 13:33:28 > OK 01/06/2020 13:33:28 > Sending device information...01/06/2020 13:33:29 > OK 01/06/2020 13:33:29 > Get credits, needed for current operation...01/06/2020 13:33:29 > OK 01/06/2020 13:33:29 > Your balance: 145 credits. 01/06/2020 13:33:29 > To perform "Reset FRP" operation you need to have 100 credits. 01/06/2020 13:33:35 > Removing write protection... 01/06/2020 13:33:39 > Execute : 0x004C 01/06/2020 13:33:40 > Writing cmd... 01/06/2020 13:33:40 > reading cmd... 01/06/2020 13:33:42 > reading cmd... 01/06/2020 13:33:44 > Reconnecting phone... 01/06/2020 13:33:45 > Phone found at port COM163 01/06/2020 13:33:45 > Mode: Emergency 01/06/2020 13:33:45 > Initializing flash...01/06/2020 13:33:47 > OK 01/06/2020 13:33:49 > Execute : 0x00BB 01/06/2020 13:33:49 > Writing cmd... 01/06/2020 13:33:49 > reading cmd... 01/06/2020 13:33:52 > reading cmd...01/06/2020 13:33:54 > OK 01/06/2020 13:33:54 > Reconnecting phone... 01/06/2020 13:33:55 > Phone found at port COM163 01/06/2020 13:33:55 > Mode: Emergency 01/06/2020 13:33:55 > Initializing flash...01/06/2020 13:33:57 > OK 01/06/2020 13:33:58 > Reading partitions...01/06/2020 13:33:58 > OK 01/06/2020 13:33:58 > Resetting FRP Lock... 01/06/2020 13:33:59 > Restore write protection... 01/06/2020 13:34:03 > Execute : 0x004C 01/06/2020 13:34:03 > Writing cmd... 01/06/2020 13:34:03 > reading cmd... 01/06/2020 13:34:05 > reading cmd... 01/06/2020 13:34:07 > Reconnecting phone... 01/06/2020 13:34:08 > Phone found at port COM163 01/06/2020 13:34:08 > Mode: Emergency 01/06/2020 13:34:08 > Initializing flash...01/06/2020 13:34:10 > OK 01/06/2020 13:34:12 > Execute : 0x00FE 01/06/2020 13:34:12 > Writing cmd... 01/06/2020 13:34:13 > reading cmd... 01/06/2020 13:34:15 > reading cmd...01/06/2020 13:34:17 > OK 01/06/2020 13:34:17 > Reconnecting phone... 01/06/2020 13:34:18 > Phone found at port COM163 01/06/2020 13:34:18 > Mode: Emergency 01/06/2020 13:34:18 > Initializing flash...01/06/2020 13:34:20 > OK 01/06/2020 13:34:21 > Reading partitions...01/06/2020 13:34:21 > OK 01/06/2020 13:34:21 > Resetting FRP lock successfully completed! 01/06/2020 13:34:21 > Performed by 3.0.2.01 Software version. 01/06/2020 13:34:21 > Elapsed Time: 0:01:11 01/06/2020 13:47:38 > -------------------------------------------------------------------------------- 01/06/2020 13:47:38 > Connecting to server ...01/06/2020 13:47:38 > OK 01/06/2020 13:47:38 > Username: omdipti1 01/06/2020 13:47:38 > Authorizing...01/06/2020 13:47:40 > OK 01/06/2020 13:47:40 > Checking balance...01/06/2020 13:47:40 > OK 01/06/2020 13:47:41 > Your balance: 45 credits. 01/06/2020 13:48:09 > -------------------------------------------------------------------------------- 01/06/2020 13:48:09 > Checking data...01/06/2020 13:48:11 > OK 01/06/2020 13:48:11 > Platform: LG MTK 01/06/2020 13:48:11 > Selected port: COM163 01/06/2020 13:48:11 > Selected baudrate: 0 01/06/2020 13:48:11 > Selected model: X430EMW 01/06/2020 13:48:11 > Selected USB connection type 01/06/2020 13:48:11 > Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) 01/06/2020 13:48:11 > or 01/06/2020 13:48:11 > Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. 01/06/2020 13:48:12 > Phone found at port COM163 01/06/2020 13:48:12 > Mode: Emergency 01/06/2020 13:48:12 > Initializing flash...01/06/2020 13:48:14 > OK 01/06/2020 13:48:15 > Model ID: LM-X430EMW 01/06/2020 13:48:15 > Platform: mt6765 01/06/2020 13:48:15 > Android version: 9 01/06/2020 13:48:15 > SW version: LMX430EMWAT-00-V10h-EEA-XX-MAR-09-2020+0 01/06/2020 13:48:15 > LAF Version: 1.1 01/06/2020 13:48:15 > Product ID: 9BFAB621DP9Y007AM 01/06/2020 13:48:15 > IMEI: 358854-10-XXXXXX-X 01/06/2020 13:48:15 > Target operator: LAO 01/06/2020 13:48:15 > Hardware: rev_10 01/06/2020 13:48:15 > Battery level: 100% 01/06/2020 13:48:15 > Reading partitions...01/06/2020 13:48:15 > OK 01/06/2020 13:48:15 > LAF Error: 80000119. 01/06/2020 13:48:16 > Checking security...01/06/2020 13:48:16 > OK 01/06/2020 13:48:16 > Reading is Blocked! 01/06/2020 13:48:16 > -------------------------------------------------------------------------------- 01/06/2020 13:48:16 > IMEI A: 358854-10-XXXXXX-X 01/06/2020 13:48:16 > IMEI B: Bad 01/06/2020 13:48:16 > Bluetooth address: Unknown 01/06/2020 13:48:16 > Wi-Fi MAC address: Unknown 01/06/2020 13:48:16 > -------------------------------------------------------------------------------- 01/06/2020 13:48:16 > Connecting to server...01/06/2020 13:48:17 > OK 01/06/2020 13:48:17 > Octopus smart card is present. 01/06/2020 13:48:17 > Checking smart card...01/06/2020 13:48:23 > OK 01/06/2020 13:48:23 > Username: omdipti1 01/06/2020 13:48:23 > Authorizing...01/06/2020 13:48:24 > OK 01/06/2020 13:48:24 > Checking balance...01/06/2020 13:48:25 > OK 01/06/2020 13:48:25 > Checking operation...01/06/2020 13:48:26 > OK 01/06/2020 13:48:26 > Sending device information...01/06/2020 13:48:28 > OK 01/06/2020 13:48:28 > Get credits, needed for current operation...01/06/2020 13:48:28 > OK 01/06/2020 13:48:28 > Too low balance to provide the security operation! 01/06/2020 13:48:28 > Your balance: 45 credits. 01/06/2020 13:48:28 > To perform "Reset FRP" operation you need to have 100 credits. 01/06/2020 13:48:28 > Performed by 3.0.2.01 Software version. 01/06/2020 13:48:28 > Elapsed Time: 0:00:19 01/06/2020 20:47:14 > Access violation at address 00BFF5AB in module 'OctoplusLG.exe'. Read of address 00000004 |
06-02-2020, 11:05 | #3 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Khakassia,MobileService Age: 48
Member: 72306 Status: Offline Thanks Meter: 193 | x420enw still locked - shou network locked all operation done but after insert card - phone still locked Добро пожаловать в Octoplus/Octopus Box LG Software version 3.0.2.01 Card S/N : -------------------------------------------------------------------------------- Connecting to server ...OK Username: oct_G49vxHs Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Платформа: LG MTK Выбранный порт: COM1 Выбранная скорость: 921600 Выбранная модель: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM46 Mode: Emergency Инициализация flash...OK Model ID: LM-X420EMW Платформа: mt6765 Android version: 9 Версия ПО: LMX420EMWAT-64-V20d-EEA-XX-JAN-20-2020+0 LAF Version: 1.1 Product ID: 9BPGAD29E6HZ017Y6 IMEI: 353615-10-502939-9 Target operator: LAO Hardware: rev_11 Battery level: 22% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353615-10-502939-9 IMEI B: Bad Адрес Bluetooth: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.0.2.01 Software version. -------------------------------------------------------------------------------- Checking data...OK Платформа: LG MTK Выбранный порт: COM1 Выбранная скорость: 921600 Выбранная модель: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM46 Mode: Emergency Инициализация flash...OK Model ID: LM-X420EMW Платформа: mt6765 Android version: 9 Версия ПО: LMX420EMWAT-64-V20d-EEA-XX-JAN-20-2020+0 LAF Version: 1.1 Product ID: 9BPGAD29E6HZ017Y6 IMEI: 353615-10-502939-9 Target operator: LAO Hardware: rev_11 Battery level: 22% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353615-10-502939-9 IMEI B: Bad Адрес Bluetooth: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: oct_G49vxHs Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Разблокировка...OK Запись зоны безопасности... Переподключение телефона... Phone found at port COM46 Mode: Emergency Инициализация flash...OK Removing write protection... Переподключение телефона... Phone found at port COM46 Mode: Emergency Инициализация flash...OKOK Переподключение телефона... Phone found at port COM46 Mode: Emergency Инициализация flash...OK Reading partitions...OK Стирание part 1...OK Переподключение телефона... Phone found at port COM46 Mode: Emergency Инициализация flash...OK Restore write protection... Переподключение телефона... Phone found at port COM46 Mode: Emergency Инициализация flash...OKOK Переподключение телефона... Phone found at port COM46 Mode: Emergency Инициализация flash...OK Reading partitions...OK Телефон успешно разблокирован! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.01 Software version. |
06-02-2020, 12:05 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. We've adde credits back to your account, please download and install 3.0.2 Software version from the Support Area or from the Octoplus website and repeat operation again P.S. There is and bug at 3.0.2.1 which we gonna fix soon, that's cause the problem Last edited by Octopus box; 06-02-2020 at 15:15. |
