Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 08-15-2017, 10:20   #1 (permalink)
Member: 583492
Thanks Meter: 124
LG-K420ds showing unfortunately error after flash [Answered]
phone was on hang on logo ,after flashing getting unfortunately the process error,i even format and hard reset but nothing works,,is there any another way to solve it???
Old 08-15-2017, 12:03   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,373
Hello.
Please repeat "Write Firmware" operation using the latest available firmware again, after post here full Software log.
Old 08-16-2017, 08:02   #3 (permalink)
Member: 583492
Thanks Meter: 124
Originally Posted by Octopus box View Post
Hello.
Welcome to Octoplus/Octopus Box LG Software version 2.7.2
Connecting to server support.octoplusbox.com:82...OK
Authorizing...OK
Checking data...OK
Platform: LG Qualcomm
Selected port: COM43
Selected model: K420DS
Reading info...
Model ID: LG-K420ds
IMEI: 357715-07-105371-6
Android version: 5.1.1
Battery level: 88%
SW Version: K42010d
Mode: Emergency
Initializing flash...OK
SW version: LGK420dsAT-00-V10d-IND-XX-JAN-20-2017+0
LAF Version: 1.2
Product ID: SM07S160312001102
Target operator: GLOBAL
Hardware: rev_12
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Opening "K420ds10d_00_0120.oct"...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Writing PrimaryGPT...OK
Writing sbl1...OK
Writing tz...OK
Writing hyp...OK
Writing rpm...OK
Writing aboot...OK
Writing sbl1bak...OK
Writing tzbak...OK
Writing hypbak...OK
Writing rpmbak...OK
Writing abootbak...OK
Writing persist...OK
Writing laf...OK
Writing boot...OK
Writing recovery...OK
Writing cust...OK
Writing factory...OK
Writing modem...OK
Writing system...OK
Writing BackupGPT...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Performed by 2.7.2 Software version.
Old 08-16-2017, 08:06   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
In what condition your device is now?
Old 08-16-2017, 10:13   #5 (permalink)
Member: 583492
Thanks Meter: 124
device is on but getting unfortunately the process error ,i can't go further
Old 08-16-2017, 10:21   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to perform Hard Reset via button combination, then write the result here.
Old 08-16-2017, 10:34   #7 (permalink)
Member: 583492
Thanks Meter: 124
already mention on first post i had did,,its a firmware problem need another update version
Old 08-16-2017, 12:54   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
If we will manage to find new firmware version for this device, we will upload it to the Support Area and inform You.
UPD: We have uploaded new V10 firmware version, please try to reflash your device again.
Old 08-16-2017, 15:15   #9 (permalink)
Member: 583492
Thanks Meter: 124
still same problem,also did hard reset with keys and box ;(
Old 08-16-2017, 15:31   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Unfortunately, we don't have any other solution at the moment.
Old 08-16-2017, 16:04   #11 (permalink)
Member: 2600625
Sonork: aly_alumni_ptc
Thanks Meter: 54
i think its problem coming from emmc sir....disable write protect is active....so if you have isp box like medusa etc...tried to click tab disable wr pt....then repeat to flash again...so ur case solved.....
Old 08-17-2018, 07:45   #12 (permalink)
Member: 1204828
Sonork: 123456
Thanks Meter: 61
octopus team pls promote this file
k420ds 1000% problem solved Unfortunately
if you liked pls press thx
https://drive.google.com/uc?id=1nWo1...xport=download
The Following 3 Users Say Thank You to a f s a r For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17686 seconds with 7 queries
