LG L-05e Unlock......[Solved] Dear Supporters & users..... i hve received 10 units of lg l-05e for unlock.... but i could not found the exact model in the octopus..... kindly some one tell me is there any way to unlock this model with octopus. or with any other device may support unlocking for this models.... Thanks for concern.... Regards. Bms-Xoder |
Hello. Please, check your PM, we have sent You test Software version. |
Some Updates... here is some Screen Shoot.... while try with selecting L-04E on your test version.... can't connect to read info...also try with read nvm & security but failed. http://www.4shared.com/img/SbLyQcz9b.../Capture_l-04e & try with L-06A i get this http://www.4shared.com/img/AikD9lksc.../Capture_l-06a Any Suggestion & help will be appreciated.... Regards. Bms-Xoder |
Please, re-install drivers for LG Android ADB, check for correct drivers link in Software manual, press Cable & Manual button, after repeat Reding all backups. |
i don't think so it might be drivers issue.... but let me try to make clear.... |
Same Result.... http://www.4shared.com/img/fmq69wbcc...85f1f8/drivers http://www.4shared.com/img/_abNkJCfb...e10/new_result Help please..... |
Please, try to select com port manually, check manual select option, then repeat operation again. |
Already try with manually ports. already try on another pc. already try reinstalling the drivers. but can't success to connect the mobile. if i select the other model its get connect & showing the version info...but while selecting (L-04e)can't connect..as above screen shoot can show you.... any solution please....? |
Please contact us to Skype, we will check where can be the problem. Our contacts You can find in our profile. |
Finally done with the help of Octopus supporters.... http://www.4shared.com/img/BPuCiNJeb...c0/unlock_done Hope in next update it will be added.... Thanks Regards. Bms-Xoder |
Thread Closed................ |
