05-21-2022, 17:28 | #1 (permalink) |
Insane Poster Join Date: May 2019 Location: .
Member: 2910407 Status: Offline Thanks Meter: 65 | Lg - lmx320ma frp not done [Answered] LG - LMX320MA FRP NOT DONE AND TOOK MY 100 CREDITS IMEI: 3585--112*8*-* Android version: 9 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX320MAAT-02-V10m-310-160-JUL-20-2021-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: ****** IMEI: 3585--112*8*-* Target operator: LAO Hardware: rev_10 Reading partitions...OK Checking operation...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: garfonline13 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 160 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to ***** 16_25-02-2022_11-35-25.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Reading partitions...OK Restore write protection... Reconnecting phone...OK Initializing flash...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: garfonline13 Authorizing...OK Checking balance...OK Your balance: 60 credits. |
