LG M160 Reset FRP problem [Solved] LG M160 FRP FAILED https://s18.postimg.org/o0tdipq0p/LG...FRP_FAILED.jpg Welcome to Octoplus/Octopus Box LG Software version 2.7.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM54 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M160 IMEI: 354843-08-174868-8 Android version: 6.0.1 Battery level: 100% SW Version: M16010c Mode: Emergency Initializing flash...OK SW version: LGM160AT-00-V10e-ORG-MCV-DEC-05-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB41S170403007354 IMEI: 354843-08-174868-8 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...Failed! LAF Error: 00000000. Performed by 2.7.8 Software version. |
Hello. In latest firmwares possibility to reset FRP by supported methods was closed (fixed). Unfortunately, no solution at the moment. We work on solution and we will release it as soon as the solution will be ready. |
You need to downgrade to version 10B! And it works like a charm! 1.download https://downloads.lg-firmwares.com/g...EU_OP_0102.kdz 2.then convert with octopus in .OCT file 3.write firmware! 4. unlock frp |
please upload new link, thanks.. |
this is the fw only search in google ,i don't know if this ,method works M16010b_00_OPEN_EU_OP_0102 |
working perfectly Checking data...OK Platform: LG Qualcomm Selected port: COM170 Selected model: M160 Reading info... Model ID: LG-M160 IMEI: 35XXXXXXXXXXXXX Android version: 6.0.1 Battery level: 100% SW Version: M16010l Mode: Emergency Initializing flash...OK SW version: LGM160AT-00-V10l-EUR-XX-DEC-05-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB46S170517000976 IMEI: 354843-08-314768-1 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "M16010b_00_OPEN_EU_OP_0102_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing tz...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing tzbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sec...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing persist...OK Writing laf...OK Writing lafbak...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Writing OP_T...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM170 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M160 IMEI: 35XXXXXXXXXXXX Android version: 6.0.1 Battery level: 100% SW Version: M16010b Mode: Emergency Initializing flash...OK SW version: LGM160AT-00-V10b-EUR-XX-JAN-02-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB46S170517000976 IMEI: 35XXXXXXXXX Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 2.8.0 Software version. |
Need firmware 10b Hi, please upload firmware M16010b_00_OPEN_EU_OP_0102_2.oct . Thanks ! Br, Titus |
Hello. You can download it from the Support Area - press "Go to Support" button at "Support & Options" tab in Software. |
Found it, downloading right now. I will flash it and post result. Thanks ! Br, Titus |
Prepairing firmware... Setting options... Reading partition... Formating USERDATA section Formating ENCRYPT section Writing signature... Writing 1/52 PrimaryGPT section... Writing 2/52 modem section... Writing 3/52 sbl1 section... Writing 4/52 tz section... Writing 5/52 rpm section... Writing 6/52 aboot section... Writing 7/52 sbl1bak section... Writing 8/52 tzbak section... Writing 9/52 rpmbak section... Writing 10/52 abootbak section... Writing 11/52 sec section... Writing 13/52 raw_resources section... Writing 14/52 raw_resourcesbak section... Writing 15/52 persist section... Writing 16/52 laf section... Writing 17/52 lafbak section... Writing 18/52 boot section... Writing 19/52 recovery section... Writing 20/52 recoverybak section... Writing 21/52 factory section... Writing 22/52 system section... Writing 23/52 system section... Writing 24/52 system section... Writing 25/52 system section... Writing 26/52 system section... Writing 27/52 system section... Writing 28/52 system section... Writing 29/52 system section... Writing 30/52 system section... Writing 31/52 system section... Writing 32/52 system section... Writing 33/52 system section... Writing 34/52 system section... Writing 35/52 system section... Writing 36/52 system section... Writing 37/52 system section... Writing 38/52 system section... Writing 39/52 system section... Writing 40/52 system section... Writing 41/52 system section... Writing 42/52 system section... Writing 43/52 system section... Writing 44/52 system section... Writing 45/52 system section... Writing 46/52 system section... Writing 47/52 system section... Writing 48/52 system section... Writing 49/52 system section... Writing 50/52 cust section... Writing 51/52 BackupGPT section... Writing 52/52 OP_T section... Reading partition... Formating RCT section Formating MPT section Finalizing... Firmware Write successfully. Performed by 1.2.1.6 Software version. |
go to this website to download it https://lg-firmwares.com/downloads-f...eu_op_0102_kdz |
frp lg M160 failed Quote:
-------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM9 Selected model: M160 Reading info... Model ID: LG-M160 IMEI: 354843-08-482595-4 Android version: 6.0.1 Battery level: 29% SW Version: M16010l Mode: Emergency Initializing flash...OK SW version: LGM160AT-00-V10l-EUR-XX-DEC-05-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB45S170727001171 IMEI: 354843-08-482595-4 Target operator: GLOBAL Hardware: rev_10 Performed by 2.8.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM9 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M160 IMEI: 354843-08-482595-4 Android version: 6.0.1 Battery level: 29% SW Version: M16010l Mode: Emergency Initializing flash...OK SW version: LGM160AT-00-V10l-EUR-XX-DEC-05-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB45S170727001171 IMEI: 354843-08-482595-4 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...Failed! LAF Error: 00000000. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.8.0 Software version. |
I also did it with the latest version of octopus 2.8.4 and the same error |
Hello. As You can see from the Software log. Quote:
