Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 09-27-2021, 16:19   #1 (permalink)
Member: 2751974
Sonork: Alladino.Ali
Thanks Meter: 4
Lg q730tm imei repair [Answered]
here full log sir i my credit deducted but imei repair not ]
Old 09-27-2021, 19:41   #2 (permalink)
Member: 2751974
Thanks Meter: 4
-------------------------------------------------------------------------------- Connecting to server 0...OK Username: safeunlocker2200 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000196A926 Checking data...OK Platform: LG MTK Selected port: COM52 Selected baudrate: 921600 Selected model: Q730TM Connecting to phone... Phone found at port COM47 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730TM9AT-00-V10r-310-240-FEB-18-2021-ARB00+0 LAF Version: 1.1 Product ID: LS01S201029002802 IMEI: 354590-11-468166-3 Target operator: LAO Hardware: rev_11 Battery level: 25% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-468166-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: safeunlocker2200 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM47 Detecting Chip Version... Platform: MT6765: 07660000 HW version: 8A00CA0000000000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM9 Detecting Chip Version... Platform: MT6765: 07660000 HW version: 8A00. CA0000000000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 07660000 HW version: 8A00CA0000000000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .13014E47314A3950381008F92CCF77CB eMMC flash chip: Unknown: G1J9P8 Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading SUPER partition... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q730TM_354590114681663_27-09-2021_19-23-18._SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cablel. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! New IMEI A: 355590-06-379xxxx Finalizing... Rebooting phone... IMEI successfully fixed! Performed by 3.1.4 Software version. -------------------------------------------------------------------------------- Selected USB connection type Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: Q730TM Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM66 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Code name: mdh50lm Android version: 10 SW version: LMQ730TM9AT-00-V10r-310-240-FEB-18-2021-ARB00+0 LAF Version: 1.1 Product ID: LS01S201029002802 IMEI: 354590-11-468166-3 Target operator: LAO Hardware: rev_11 Battery level: 24% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-468166-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.1.4 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: safeunlocker2200 Authorizing...OK Checking balance...OK Your balance: 0 credits.
Old 09-28-2021, 07:02   #3 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,136
Hello.
We added your one more attempt.
Please, try to repeat Repair IMEI operation once again and post here results. We will check it.
Old 09-28-2021, 11:49   #4 (permalink)
Member: 2751974
Thanks Meter: 4
got same problem on last step modem not show lost again credit
here is log to long i have attached text log please check i perform again but no luck i lost my credit again
Old 09-28-2021, 12:16   #5 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
Please, check your PM.
Page generated in 0.18825 seconds with 9 queries
