01-13-2021, 21:35 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1151408 Status: Offline Thanks Meter: 2 | LG Q730tm process finish but not unlock [Solved] I have unlocked the q730tm, it seems that I finished the process but it is still blocked and it consumed 100 credits Selected USB connection type Work ID: 00000000006A8BF9 Checking data...OK Platform: LG MTK Selected port: COM14 Selected baudrate: 921600 Selected model: Q730TM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM4 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10p-310-120-NOV-11-2020-ARB00+0 LAF Version: 1.1 Product ID: VP05S200724008153 IMEI: 354527-11-577129-1 Target operator: LAO Hardware: rev_11 Battery level: 11% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-577129-1 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_354527115771291_13-01-2021_11-34-17.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: audic0m_ab Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 102 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions... Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: audic0m_ab Authorizing...OK Checking balance...OK Your balance: 2 credits. |
01-14-2021, 08:56 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Online Thanks Meter: 2,136 | Hello. We added you one more attempt. Please, download and install latest software version and repeat Unlock operation once again, post here results. |
01-14-2021, 16:21 | #4 (permalink) |
Member: 1151408 Status: Offline Thanks Meter: 2 | operation succesfull thanks octopus team!! Selected USB connection type Work ID: 00000000006BCF31 Checking data...OK Platform: LG MTK Selected port: COM14 Selected baudrate: 921600 Selected model: Q730TM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM4 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10p-310-120-NOV-11-2020-ARB00+0 LAF Version: 1.1 Product ID: VP05S200724008153 IMEI: 354527-11-577129-1 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-577129-1 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_3545271157xxx291_14-01-2021_09-05-41.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: audic0m_ab Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 102 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.8 Software version. |
The Following 2 Users Say Thank You to abnerjosue For This Useful Post: |
