03-08-2019, 11:44 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | After flashed phone screen displaying in small size from the bottom and touch not working......what is the issue and how to solve it? Last edited by amanvir; 03-08-2019 at 11:54. |
03-08-2019, 12:51 | #5 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM61 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM42 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: VS03S181010002645 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-533222-0 MEID: 359634-09-533222 Bluetooth address: 00:57:C1:73:A9:81 Wi-Fi MAC address: 38:30:F9:1D:BA:8D SPC: 537934 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "SP200_359634095332220_08-03-2019_11-32-21.EEP" -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20013b_to_X210ULMA10d_for_unlock_3.oct"...OK Setting options...OK Selecting firmware partitions...OK Selected default partitions! Reading partitions...OK Do you want to format User Data? Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing pgpt...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...OK Writing lafbak...OK Writing ftm...OK Writing cache...OK Writing OP...OK Writing userdata...OK Formating RCT...OK Finalizing...OK Performed by 2.9.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM61 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM42 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LAF Version: 1.1 Product ID: VS03S181010002645 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-533222-0 MEID: 359634-09-533222 Bluetooth address: 00:57:C1:73:A9:81 Wi-Fi MAC address: 38:30:F9:1D:BA:8D SPC: 537934 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Opening "SP200_35963409533222_07-03-2019_12-52-10.eep"...OK Writing EEPROM...OK EEPROM succesfully repaired. Performed by 2.9.3 Software version. |
The Following User Says Thank You to amanvir For This Useful Post: |
03-08-2019, 14:02 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Please, try to repeat Unlock operation with that firmware once again, i mean perform Hard Reset and reflash the device with SP20013b_to_X210ULMA10d_for_unlock_3.oct once again. Note: that method not guarantee You a 100% working solution, all these steps You gonna perform at your worn risk. |
03-08-2019, 14:58 | #8 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | I already flashed it 2 times since yesterday and just now tried again with LGUP but still the same touch not working and screen size is small from bottom |
03-08-2019, 15:19 | #9 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Let me explain you from the begning what i did step by step First i took backup of eeprom 2 times and both backups are not same size one is 94kb and another is 158kb After flashed it i restore the 94kb eeprom backup then after see that screen issue i tried second backup of eeprom which is 158kb size but issue not solve Then this morning i flashed it again with octoplus but issue remains the same Then i hardreset it and used LGUP to flash it and same issue still remains Now i'm going to flash it again by doing hardreset first then flashing with octoplus and will post the result..... |
03-08-2019, 17:28 | #10 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM61 Selected baudrate: 115200 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM42 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: VS03S181010002645 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-533222-0 MEID: 359634-09-533222 Bluetooth address: 00:57:C1:73:A9:81 Wi-Fi MAC address: 38:30:F9:1D:BA:8D SPC: 537934 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "SP200_359634095332220_08-03-2019_15-24-30.EEP" -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20013b_to_X210ULMA10d_for_unlock_3.oct"...OK Setting options...OK Selecting firmware partitions...OK Selected default partitions! Reading partitions...OK Do you want to format User Data? Sending signature...OK Writing preloader...OK Writing pgpt...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...OK Writing lafbak...OK Writing ftm...OK Writing cache...OK Writing OP...OK Writing userdata...OK Formating RCT...OK Finalizing...OK Performed by 2.9.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM61 Selected baudrate: 115200 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM42 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LAF Version: 1.1 Product ID: VS03S181010002645 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-533222-0 MEID: 359634-09-533222 Bluetooth address: 00:57:C1:73:A9:81 Wi-Fi MAC address: 38:30:F9:1D:BA:8D SPC: 537934 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...OK Opening "SP200_35963409533222_07-03-2019_12-52-10.eep"...OK Writing EEPROM...OK EEPROM succesfully repaired. Performed by 2.9.3 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM61 Selected baudrate: 115200 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM42 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: LMX210ULMAAT-00-V10d-LAO-COM-MAR-16-2018-ARB00+ 0 LAF Version: 1.1 Product ID: VS03S181010002645 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 359634-09-533222-0 MEID: 359634-09-533222 Bluetooth address: 00:57:C1:73:A9:81 Wi-Fi MAC address: 38:30:F9:1D:BA:8D SPC: 537934 -------------------------------------------------------------------------------- Reading security area...OK Backup saved to "SP200_359634095332220_08-03-2019_16-01-57.EEP" -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20013b_to_X210ULMA10d_for_unlock_3.oct"...OK Setting options...OK Selecting firmware partitions...OK Selected default partitions! Reading partitions...OK Do you want to format User Data? Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing pgpt...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...OK Writing lafbak...OK Writing ftm...OK Writing cache...OK Writing OP...OK Writing userdata...OK Formating RCT...OK Finalizing...OK Performed by 2.9.3 Software version. |
03-09-2019, 09:47 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Unfortunately, we don't have any other solution, try to reflash your device with stock firmware to restore the device into initial state. |
03-09-2019, 14:23 | #13 (permalink) |
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Problem solved phone unlocked and working perfect After tried flash it with SP20013b_to_X210ULMA10d_for_unlock_3.oct so many times and finally i make it work with the help of google search and found this https://www.mylgphones.com/sprint-lg...-firmware.html I used this file X210ULMA11a_00_NAO_US_OP_0921.kdz Note:- There is no stock firmware available for the SP200 at the moment. Last edited by amanvir; 03-09-2019 at 14:30. |
The Following 5 Users Say Thank You to amanvir For This Useful Post: |
04-24-2019, 02:28 | #15 (permalink) |
Freak Poster Join Date: Jan 2017 Location: Ukraine, Kiev
Member: 2667818 Status: Offline Thanks Meter: 42 | I have the same issue and NO it doesn't help 1st fw - No touch and part of screen works 2nd - only logo and bootloop in recovery mode if I try to enter into it |
