07-24-2018, 01:36 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: milagro
Member: 262145 Status: Offline Sonork: 100.1668642 Thanks Meter: 98 | LG SP200 firmware request [Answered] In the middle of Writing system section process suddenly error! Now I can't flash because of "writing preloader failed" Logs: Code: Platform: LG MTK Selected port: COM124 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM125 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: SP20010b_00 LAF Version: 1.1 Product ID: CT66S180208008164 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: --------------------- MEID: -------------------------2 Bluetooth address: 00:3D:E8:79:7D:10 Wi-Fi MAC address: 00:3D:E8:EF:12:1D SPC: 089347 -------------------------------------------------------------------------------- Performed by 2.8.7.6 Software version. Code: Checking data...OK Platform: LG MTK Selected port: COM124 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM125 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: SP20010b_00 LAF Version: 1.1 Product ID: CT66S180208008164 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: ----------------------- MEID:-------------------------- Bluetooth address: 00:3D:E8:79:7D:10 Wi-Fi MAC address: 00:3D:E8:EF:12:1D SPC: 089347 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20010b_to_X210ULMA10d_for_unlock.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...Failed! Performed by 2.8.7.6 Software version. Thanks in advance. REGARDS Last edited by Octopus box; 07-24-2018 at 09:28. |
The Following User Says Thank You to kelvinator For This Useful Post: |
07-24-2018, 15:42 | #3 (permalink) |
Member: 262145 Status: Offline Sonork: 100.1668642 Thanks Meter: 98 | Thanks for sharing test software octoplus team, now there is no error writing preloader but system section reaches 13% and shows error. Code: Checking data...OK Platform: LG MTK Selected port: COM125 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM127 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: SP20010b_00 LAF Version: 1.1 Product ID: CT66S180208008164 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: xxxxxxxxxxxxxxxx MEID: xxxxxxxxxxxxxxxxx Bluetooth address: 00:3D:E8:79:7D:10 Wi-Fi MAC address: 00:3D:E8:EF:12:1D SPC: 089347 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20010b_to_X210ULMA10d_for_unlock.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...Failed! Performed by 2.8.7.7 Software version. |
07-24-2018, 15:59 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Tomorrow we will prepare new test Software version for You. |
07-24-2018, 19:22 | #5 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 415442 Status: Offline Thanks Meter: 3 | flash ok and same problem Welcome to Octoplus/Octopus Box LG Software version 2.8.7.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM3011 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: SP20010b_00 LAF Version: 1.1 Product ID: VS02S180326003665 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 351980-09-659201-7 MEID: 351980-09-659201 Bluetooth address: 48:60:5F:B1:05:1E Wi-Fi MAC address: 48:60:5F:1D:5C:E3 SPC: 750614 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20010b_to_X210ULMA10d_for_unlock.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...OK Writing lafbak...OK Writing ftm...OK Writing cache...OK Writing OP...OK Writing userdata...OK Formating RCT...OK Finalizing...OK Performed by 2.8.7.7 Software version. only says factory reset in display and reboot |
The Following User Says Thank You to serllito For This Useful Post: |
07-25-2018, 17:36 | #7 (permalink) |
Member: 262145 Status: Offline Sonork: 100.1668642 Thanks Meter: 98 | Latest version, same problem. (Just in case) phone was ok before writing this special firmware. I just tried to unlock and I'm stuck in that section and I can't even revert it beacuse I can't find Sp200 kdz file. Tha's the reason I request the file. Please octoplus team, help me here. Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: SP200 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM125 Mode: Emergency Initializing flash...OK Model ID: LM-X210ULMA Platform: mt6750 Android version: 7.1.2 SW version: SP20010b_00 LAF Version: 1.1 Product ID: CT66S180208008164 IMEI: Target operator: LAO Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: xxxxxxxxxxxxxxxxxxx MEID: xxxxxxxxxxxxxxxx Bluetooth address: 00:3D:E8:79:7D:10 Wi-Fi MAC address: 00:3D:E8:EF:12:1D SPC: 089347 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "SP20010b_to_X210ULMA10d_for_unlock.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing preloader...OK Writing lk...OK Writing lk2...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing logo...OK Writing lo_bak_go...OK Writing secro...OK Writing tee1...OK Writing tee2...OK Writing rct...OK Writing factory...OK Writing efuse...OK Writing md1img...OK Writing md1dsp...OK Writing md1arm7...OK Writing md3img...OK Writing system...Failed! Performed by 2.8.8 Software version. W.B.R. |
07-25-2018, 17:43 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfrotunately, we don't have the firmware for SP200 at the moment. As soon as we will get it, we will upload it into the Support Area and inform You. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
07-26-2018, 07:53 | #9 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2279482 Status: Offline Thanks Meter: 1 | 502/5000 Traduci da: Inglese I have the same mobile phone lg sp200 lock sprint Thank you for the update! Unfortunately, this firmware does not have an unlock code programmed in. This firmware can not be used to unlock the firmware with a non-locked version using special hardware equipment (cable boxes). If you have any replacement device, please let us know and we will be happy to assist you. Thank you and sorry again we could not help this time! |
08-07-2018, 05:42 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | No, we still don't have firmware for this device. |
08-13-2018, 06:29 | #14 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2738165 Status: Offline Thanks Meter: 23 | This is really NUTS. I hate it when carriers/ manufacturers release devices without software support. I tried special firmware and it write successfully. only problem is that it turns on to"factory data reset" and loops right there. I have searched far and wide for firmware and was unable to get it. I tried contacting the carrier and LG but with no avail. |
The Following 2 Users Say Thank You to suprxme For This Useful Post: |
10-19-2018, 13:36 | #15 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Dominican Republic
Member: 482218 Status: Offline Thanks Meter: 119 | could someone send me this fw. im responsible for any outcome. [email protected] |
The Following User Says Thank You to el_venga For This Useful Post: |
