03-18-2020, 15:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2017
Member: 2711286 Status: Offline Thanks Meter: 27 | m400dy always cant remove frp [Answered] -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM849 Selected baudrate: 0 Selected model: M400DY Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM28 Mode: Emergency Initializing flash...OK Model ID: LG-M400DY Platform: mt6750 Android version: 7.0 SW version: LGM400DYAT-00-V10c-AME-XX-APR-07-2017+0 LAF Version: 1.1 Product ID: BS06S180104001151 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 356547-08-318207-1 IMEI B: 356547-08-318208-9 Bluetooth address: 084:6A:28:95:31 Wi-Fi MAC address: 48:60:5F:94:60:4A SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 00000000. Trying third method...Failed! Reset FRP operation for M400DY will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...Failed! Error code: DCASVASCSD Performed by 3.0.1.01 Software version. |
03-19-2020, 11:29 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, check your PM, we've sent You test Software version |
06-30-2020, 15:10 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You've tried something, then post here full Software log, we don't need to guess what You've done or not, follow simply rules and You will get answer and help as soon as possible |
06-30-2020, 16:36 | #6 (permalink) |
Member: 2711286 Status: Offline Thanks Meter: 27 | Checking data...OK Platform: LG MTK Selected port: COM11 Selected baudrate: 0 Selected model: M400DY Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM28 Mode: Emergency Initializing flash...OK Model ID: LG-M400DY Platform: mt6750 Android version: 7.0 SW version: LGM400DYAT-00-V10c-AME-XX-APR-07-2017+0 LAF Version: 1.1 Product ID: BS06S180104001151 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 356547-08-318207-1 IMEI B: 356547-08-318208-9 Bluetooth address: 084:6A:28:95:31 Wi-Fi MAC address: 48:60:5F:94:60:4A SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 00000000. Trying third method...Failed! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Login error: Wrong username! Performed by 3.0.2.03 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: khaledrepa Authorizing...OK Checking balance...OK Your balance: 0 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM11 Selected baudrate: 0 Selected model: M400DY Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM28 Mode: Emergency Initializing flash...OK Model ID: LG-M400DY Platform: mt6750 Android version: 7.0 SW version: LGM400DYAT-00-V10c-AME-XX-APR-07-2017+0 LAF Version: 1.1 Product ID: BS06S180104001151 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 356547-08-318207-1 IMEI B: 356547-08-318208-9 Bluetooth address: 084:6A:28:95:31 Wi-Fi MAC address: 48:60:5F:94:60:4A SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 00000000. Trying third method...Failed! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: khaxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Too low balance to provide the security operation! Your balance: 0 credits. To perform "Reset FRP" operation you need to have 100 credits. Performed by 3.0.2.03 Software version. |
07-01-2020, 07:46 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As we can see the problem isn't same! It's clearly says, what You need to do: "To perform "Reset FRP" operation you need to have 100 credits." |
