06-26-2022, 00:09 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: EARTH
Member: 259397 Status: Offline Thanks Meter: 76 | lg v50 imei repair failed [Answered] unfortunately cancel my job during process i try to repair again but software says you dont have balance Welcome to Octoplus/Octopus Box LG Software version 3.1.9 -------------------------------------------------------------------------------- Work ID: 000000000181D131 Checking data...OK Platform: LG Qualcomm Selected port: COM25 Selected model: V500N Reading info... Found model LMV500NA: ÿh0 at port COM25 Model ID: LM-V500N IMEI: 355693-10-517153-5 Android version: 11 Battery level: 80% Mode: Normal Firmware compiled date: Dec 20 2021 Firmware compiled time: 02:00:00 Firmware released date: Feb 21 2022 Firmware released time: 18:04:55 SW Version: MPSS.HE.1.5.3.c1-00125-SM8150_GENFUSION_PACK- 1.400300.8.410866.8 IMEI: 355693-10-517153-5 SPC: 000000 Fixing IMEI... New IMEI: 356343-22-127030-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.9 Software version. -------------------------------------------------------------------------------- Work ID: 000000000181D186 Checking data...OK Platform: LG Qualcomm Selected port: COM25 Selected model: V500N Reading info... Model ID: LM-V500N IMEI: 355693-10-517153-5 Android version: 11 Battery level: 80% Mode: Normal Firmware compiled date: Dec 20 2021 Firmware compiled time: 02:00:00 Firmware released date: Feb 21 2022 Firmware released time: 18:04:55 SW Version: MPSS.HE.1.5.3.c1-00125-SM8150_GENFUSION_PACK- 1.400300.8.410866.8 IMEI: 355693-10-517153-5 SPC: 000000 Fixing IMEI... New IMEI: 356343-22-127030-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-V500N Phone firmware version: LMV500NAT-00-V30e-LAO-COM-FEB-21-2022+0 Kernel version: 4.14.190-perf+ (jenkins@MCSBS9R21) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Mon Feb 21 18:36:48 KST 202 Android version: 11 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: KT Connecting to server 0...OK Octopus smart card is not present. Checking Activations...OK Username: gsmcity02 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...OK Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...Canceled! Backup saved to "V500N_355693105171535_25-06-2022_14-46-07.qcn" Performed by 3.1.9 Software version. -------------------------------------------------------------------------------- Work ID: 000000000195411E Checking data...OK Platform: LG Qualcomm Selected port: COM25 Selected model: V500N Reading info... Model ID: LM-V500N IMEI: 355693-10-517153-5 Android version: 11 Battery level: 81% Mode: Normal Firmware compiled date: Dec 20 2021 Firmware compiled time: 02:00:00 Firmware released date: Feb 21 2022 Firmware released time: 18:04:55 SW Version: MPSS.HE.1.5.3.c1-00125-SM8150_GENFUSION_PACK- 1.400300.8.410866.8 IMEI: 355693-10-517153-5 SPC: 000000 Fixing IMEI... New IMEI: 356343-22-127030-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.9 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001954129 Checking data...OK Platform: LG Qualcomm Selected port: COM25 Selected model: V500N Reading info... Model ID: LM-V500N IMEI: 355693-10-517153-5 Android version: 11 Battery level: 81% Mode: Normal Firmware compiled date: Dec 20 2021 Firmware compiled time: 02:00:00 Firmware released date: Feb 21 2022 Firmware released time: 18:04:55 SW Version: MPSS.HE.1.5.3.c1-00125-SM8150_GENFUSION_PACK- 1.400300.8.410866.8 IMEI: 355693-10-517153-5 SPC: 000000 Fixing IMEI... New IMEI: 356343-22-127030-3 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...OK Model ID: LM-V500N Phone firmware version: LMV500NAT-00-V30e-LAO-COM-FEB-21-2022+0 Kernel version: 4.14.190-perf+ (jenkins@MCSBS9R21) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Mon Feb 21 18:36:48 KST 202 Android version: 11 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: KT Connecting to server 0...OK Octopus smart card is not present. Checking Activations...OK Username: gsmcity02 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Too low balance to provide the security operation! Your balance: 0 credits. To perform "Repair IMEI" operation you need to have 100 credits. Performed by 3.1.9 Software version. -------------------------------------------------------------------------------- Last edited by Octopus support; 06-27-2022 at 08:04. |
